Author: Subject: PS3 streaming
liam.mccaffrey
posted on 6/12/10 at 11:23 PM Reply With Quote
PS3 streaming
Anyone know if its possible to stream the video output of a PS3 over a LAN?
Build Blog
Build Photo Album
Paradoxia0
posted on 6/12/10 at 11:45 PM Reply With Quote
Hi
I have tried MediaLink from my Mac and that seems to work nicely... I have their other utility for Xbox streaming and am very happy with it. I can't say if there is a good PC equivalent.
Hope that is some help
Mark
There is no replacement for displacement...
RK
posted on 7/12/10 at 12:27 AM Reply With Quote
It says it can on the box. I've not opened mine yet, but when I do, I'll be putting up notices to play rFactor, GTR2, and F1 2010 with some people on the board. Don't know if you can with Richard Burns Rally.
SeanStone
posted on 7/12/10 at 03:53 AM Reply With Quote
depends what you mean by video output. if you have a video or sound file on your computer, that can be played over lan via the ps3, but the ps3 wont stream anything via its own lan output
liam.mccaffrey
posted on 7/12/10 at 07:45 AM Reply With Quote
Just to clrify I don't want to stream TO the PS3 I want to somehow get its video (or any video signal for that matter) out over a LAN. It must be possible even if additional hardware is required.
Build Blog
Build Photo Album
martyn_16v
posted on 7/12/10 at 12:57 PM Reply With Quote
Do you actually need it to go over the network itself (i.e. have an IP, be able to pass across routers etc) or just use some cat5 cable to pass the signal?
The latter is fairly easy, there are both HDMI-Cat5 and Scart-Cat5 converters out there.
liam.mccaffrey
posted on 7/12/10 at 01:55 PM Reply With Quote
that would work fine but I need to avoid using wires.
I think I have found a wry to do it now
Build Blog
Build Photo Album
stevebubs
posted on 7/12/10 at 02:28 PM Reply With Quote
http://en.wikipedia.org/wiki/Remote_Play#Remote_Play_to_PC
liam.mccaffrey
posted on 7/12/10 at 05:12 PM Reply With Quote
Apparently this is pretty straightforward using a capture card and VLC media player to stream the video
Build Blog
Build Photo Album
