posted on 8/12/10 at 01:47 PM |
oooooh whatever next ...
carbon fibre screws?
Carbon Fibre Bolts
Suitable for Bottlecages, Front Derailleurs or Rear Derailleurs.
Not Suitable for Seatposts, Handlebars or Stems.
jossey
posted on 8/12/10 at 01:51 PM |
oh ye baby that will be great.
i could save a few grams off my stupidly over weight kona.
i thought my groupset was light when i bought it back in 1995 but it turns out xtr groupset was never light lol
so if i use it for my bottle holder. ill need some super light drink lol
cheers
MikeR
posted on 8/12/10 at 02:09 PM |
get cola - but make the bubbles helium so they help reduce the weight of the drink!
jossey
posted on 8/12/10 at 02:15 PM |
lol
david
blakep82
posted on 8/12/10 at 02:22 PM |
helium bubblewrap
i want some to hold my dasboard on
[Edited on 8/12/10 by blakep82]
________________________
balidey
posted on 8/12/10 at 02:48 PM |
Have a wee before you go riding and it saves more for zero cost
Dutch bears have terrible skin due to their clogged paws
loggyboy
posted on 8/12/10 at 03:58 PM |
Disclaimer on them states they arent for any thing to take weight. lol
And are they gonna be any lighter than ally?
[Edited on 8/12/10 by loggyboy]
greggors84
posted on 8/12/10 at 10:07 PM |
Surely at that price you might as well use Ti. Got to be as light and a lot stronger!
Maybe not as bling!
Chris
The Magnificent 7!
matt_gsxr
posted on 9/12/10 at 10:13 AM |
Carbon fibre 1.7g/cc
Aluminium 2.7g/cc
Titanium 4.5g/cc
Stainless 7.8g/cc
cc is cubic centimeter.
I still think that these are going too far, but not much point in saying they aren't light.
Matt
hicost blade
posted on 9/12/10 at 10:49 AM |
ooooh that makes me want to put on my skin tight lycra jump suit, sperm shaped helmet and go and cycle side by side with my mate down a duel
carriageway............................
Carbon bolts, about as much use as titanium bolts, use...........less
I can kind of see the point in a carbon dowel, but with a thread on it!?! Do these people know anything about material properties
urrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrrr NO!
posted on 9/12/10 at 11:37 AM |
^^^^ is what I was thinking. I may be wrong but the thing that makes carbon fibre strong is the mat. The thread on these bolts is much finer than
the mat filaments so I do not see any strength advantage - may just as well make them from resin?.
These appeal to the "it's make from CF so it must be good"..... but that is not alwauys the case (recently purchased RaceFace CF
bars that are no lighter than my alloy ones ... although they may be stiffer).
I have used aluminium alloy to hold bottle cages to carry 1 l or so of water and not had them break.
Also I have some nylon 6.6 screw, density 1.15 g/cm3 so even lighter than CF (for blocking off the holes in the frame rather than for carrying
weight) and was wondering if they could hold a bottle cage with a full water botle.
properties are:
Tensile strength at yield 527 MPa 45 – 95
Elongation at yield 527 % 3 - 30
Elongation at break 527 % 5 – 150
Tensile Modulus 527 MPa 1600 - 3900
Flexural modulus 178 MPa 2000 – 3000
no idea how those number compare to Steel or aluminium alloy though.
Not sure what you mean by Ti bolts being no good - Ti is used for many application that require strength and much lightness. Just the other day I
fitted disc brake rotos using Ti bolts ....if you don't hear from me ever again after this weekend you can assume brakes failed.
[Edited on 9/12/10 by 02GF74]
