Author: Subject: turbo exhaust size
beaver34
posted on 8/12/10 at 10:54 PM Reply With Quote
turbo exhaust size
im having a 1600 turbo, what size exhaust do i want to be having? i have a 2.5" silencer at the moment i would like to keep, im looking to run around 20psi and 250ish bhp will 2.5" flow enough?
thanks
Strontium Dog
posted on 8/12/10 at 11:16 PM Reply With Quote
That should be fine presuming it is a free flowing system! I run a 2.5" pipe after a 3" DP on a 300hp 2.0L engine.
ashg
posted on 8/12/10 at 11:27 PM Reply With Quote
I ran 325bhp on a 2.5inch exhaust. If you go too big you will lose your back pressure and keep blowing oil seals on the turbo
[Edited on 8/12/2010 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
beaver34
posted on 9/12/10 at 09:22 AM Reply With Quote
so it would be ok with 2.5" downpipe?
NS Dev
posted on 9/12/10 at 09:46 AM Reply With Quote
yea for that power it will be fine.
atspeed racing
posted on 9/12/10 at 04:05 PM Reply With Quote
2.5" is fine
sorens2
posted on 9/12/10 at 06:23 PM Reply With Quote
I have done 390 bhp on a 2.5" with a 2.2 L engine.
Soren S2
madteg
posted on 9/12/10 at 07:35 PM Reply With Quote
I run 2.5 on 320 BHP works for me.
bimbleuk
posted on 10/12/10 at 09:34 AM Reply With Quote
I had 2" on my Striker which was from when it was NA. That flowed 270BHP but was at the limit as the exhaust blued along most of the system at bends or restrictions. I wanted to go to 2.25" but ended up with 2.5" parts as they were more readily available.
That was supercharged though and my preference for 2.25" was purely down to restricting noise. The turbo will reduce that so isn't such an issue.
westy turbo
posted on 10/12/10 at 10:30 AM Reply With Quote
63mm or 2.5 inches is spot on,juts keep an eye on the EGT temps,you might need a 70mm down pipe.so will use the
28rs turbo?
