Author: Subject: Some good info on Glycol Coolant
posted on 2/1/11 at 02:41 PM Reply With Quote
Some good hard info why it isn't a good idea to fill your rad with high concentrations of glycol coolant, it applies equally well to Ethylene Glycol and propylene glycol.
From Rolls-Royce Merlin entry on Wikipedia http://en.wikipedia.org/wiki/Rolls-Royce_Merlin
Another improvement, allowing the XX and future Merlin variants to run some 70 degrees C cooler, was the use of a 70/30% water/glycol coolant mix rather than the 100% glycol of the earlier versions. This substantially improved engine life and reliability, removed the fire hazard of the flammable ethylene glycol.
MakeEverything
posted on 2/1/11 at 04:01 PM Reply With Quote
I thought that was common knowledge though, and manufacturers recommendations on Glycol that ive purchased for closed water systems has always specified the dosage.
Kindest Regards,
Richard.
Bluemoon
posted on 2/1/11 at 04:32 PM Reply With Quote
I have heard of people running at 100%.. Not on this forum though..
Dan
posted on 2/1/11 at 05:06 PM Reply With Quote
Evans coolant from the published info on the net working from the boil and freezing points is near 100% Proplylene Glylcol ---- snake oil.
prawnabie
posted on 2/1/11 at 05:56 PM Reply With Quote
I wouldnt take anything of wikipedia as hard info!
Ninehigh
posted on 2/1/11 at 11:58 PM Reply With Quote
Wikipedia, the internet version of the "bloke down the pub"!
bimbleuk
posted on 3/1/11 at 08:15 AM Reply With Quote
Maybe now but the engine was designed in the 1930s!
posted on 3/1/11 at 09:35 AM Reply With Quote
readd the article before making comment the article references an authoritative source for that particular piece of information.
bigpig
posted on 3/1/11 at 10:37 AM Reply With Quote
The link to the actual Ethylene Glycol reference is quite good. Discusses why a 50/50 mix is good for car use due to increased specific heat capacity.
