Author: Subject: number plates
knight
posted on 25/6/04 at 10:47 PM Reply With Quote
number plates
hi guys does anyone know where i can get those stick on number plates ,ie so i can stick it on the top of the nose cone .
i keep on ripping them off the bottom of my nosecone on them speed humps
cheers
RoadkillUK
posted on 26/6/04 at 01:43 AM Reply With Quote
To my knowledge, I think they aren't legal.
P.S. I don't know where you can get them from.
Roadkill - Lee
www.bradford7.co.uk
Latest Picture (14 Sept 2014)
Chris_R
posted on 26/6/04 at 06:58 AM Reply With Quote
you can do it with cut vinyl. try a couple of local sign makers. They should have a plotter to cut the vinyl and the vinyl it's self is fairly inexpensive. The letters and the white background would be cut seperately, the background applied to the nose cone first and the letters over the top of that. If you can''t find a reasonable sign maker try looking for those precut letters that are available at some automotive shop's and bike shops. IMHO it'll look better, if you're gonna go the sign maker route, to ask him to put a 15MM radius on the corners of the white background. Shameless pulg... try finding your local Signs Express.
A bit of slapstick never hurt anyone.
http://www.chris.renney.dsl.pipex.com/
knight
posted on 26/6/04 at 09:28 AM Reply With Quote
cheers guys i will try the vinyl route
givemethebighammer
posted on 26/6/04 at 11:51 AM Reply With Quote
I thought europa used to sell them ?
http://www.europaspares.com/
James
posted on 26/6/04 at 11:58 AM Reply With Quote
Hi Knight,
Where in Surrey are you based?
James of Guildford.
Northy
posted on 26/6/04 at 12:03 PM Reply With Quote
I fancy one of the little bike style front plates.
Anyone know where you can get them?
Graham
posted on 26/6/04 at 02:59 PM Reply With Quote
They only do rear for bikes and
You can't get them for bikes any more as they are not road legal. Bike rear plates have to be square now.
nicklondon
posted on 26/6/04 at 04:52 PM Reply With Quote
what you need is a no. plate like the wrc teams are allowed to use.
Chris_R
posted on 26/6/04 at 05:02 PM Reply With Quote
if you want a small plate you can have one made.... at a sign makers. Get a bit of clear acrylic cut to the size you want the plate to be, have the letters cut as a mirror image, apply them to the rear of the acrylic and then apply your background colour, either yellow or white. Hey presto, profesional looking tiny plates.
Chris_R
posted on 26/6/04 at 05:04 PM Reply With Quote
You do have to be registered to make plates, but I don't think a small sign making firm would ask you for ID, like Halfords do. Don't think we would.
[Edited on 26/6/04 by Chris_R]
paulf
posted on 26/6/04 at 08:12 PM Reply With Quote
My local accessory shop sells front and rear stick on plates.They are marked for show use and not to be used on the road. Iwas also told that they were illegal when i bought a rear stick on for my trailer. The letters are also available but i made mine up in word and adjusted the font and size to look correct, then printed them and cut them out.I then stuck them to the backing plate and put a perspex front from an old number plate over the top.
It was a lot of hassle to avoid having to go back to the shop with reg documents etc.
Paul.
andyps
posted on 26/6/04 at 09:21 PM Reply With Quote
You can at least get the correct font for number plates from the web - a link was posted on this site some time ago.
Pretty sure anything other than the "official" types are illegal and would fail at MOT time, but stick on ones can certainly look good.
mangogrooveworkshop
posted on 26/6/04 at 11:11 PM Reply With Quote
Signmakers charge a min charge for the job of £45 + vat the will cut any thing no questions asked most dont know that you need to register to make car plates so no bother there. www.signarama.co.uk a whole chain of franchises that need the biz shamless plug (mate has edinburgh branch)
Generate your cut file in Adobe Illustrator 10 and they cut straight from that. AI format
posted on 26/6/04 at 11:29 PM Reply With Quote
Not for road use they aren't. They may get round some regs if they are import vehicles but for vehicles registered here the regs are different.
http://www.personallyyours.co.uk/number-plates.htm
nicklondon
posted on 27/6/04 at 10:30 AM Reply With Quote
but the focus wrc is run with british reg. no. so it seems its one law for them and another for joe public.
Chris_R
posted on 27/6/04 at 06:38 PM Reply With Quote
if you are gonna send graphics to a sign maker, or printer for that matter, you'd prolly be wise to send dulpicates of your artwork as both an EPS file and an Illustrator file. You could also use Corel Draw to set the layout.
Noodle
posted on 27/6/04 at 08:19 PM Reply With Quote
That's a good thing surely? I'm fully in support of inequalties if it furthers the breed.
Neil.
Your sort make me sick
Chris_R
posted on 27/6/04 at 10:22 PM Reply With Quote
Free Template
If you'd like a GB style number plate template you can download mine here in EPS format. All you need to do is add the lettering. Guidelines for letter size and spacing for plates fitted after 1st September 2001 can be found on the DVLA's web site.
Chris_R
posted on 27/6/04 at 10:59 PM Reply With Quote
The mandatory UK number plate font is called Charles Wright. Does anyone have it?
Chris_R
posted on 27/6/04 at 11:09 PM Reply With Quote
...or even a large good quality image? Bigger and better than this one? Rescued attachment numberplatefont_220101.gif
posted on 28/6/04 at 07:44 AM Reply With Quote
I have a Windows TTF (True Type Font) file for the numberplate characters, which can be used in Word and the like.
Trouble is, I have no idea how to post it here... anyone know how to make a ZIP file available?
timf
posted on 28/6/04 at 08:32 AM Reply With Quote
as an attachment david
posted on 28/6/04 at 08:54 AM Reply With Quote
Let's see if this works... it didn't the first time I tried...
Cooo! it did!
[Edited on 28/6/04 by David Jenkins]
Chris_R
posted on 28/6/04 at 05:21 PM Reply With Quote
David,
That's cracking, thanks very much.
For anyone who's interested i've updated my EPS file to include all the relevant letters and numbers from Davids number plate TTF, as well as the original euro style plate template. All you need do is copy, paste, arrange, and deliver to a sign maker and hey presto, adhesive plates. Can't get much easier than that.
For everyone else, should we have a funny number plate competition, or should I get out more? No real need to answer that.
The template is available from the index page of my web site, which is at http://www.chris.renney.dsl.pipex.com/, as it's too big to attach to this message.
Chris.
[Edited on 28/6/04 by Chris_R]
