| posted on 10/1/11 at 12:13 PM |
FS: Caterham Speedo & VDO Gauges
All in reasonable nick. The odd small dint and / or scratch, but otherwise fine.
CATERHAM BRANDED SPEEDO
Does not have the Odometer reset attachment, but this is standards Smiths, so shouldn't be hard to source.
£45
VDO TACHO
£55
VDO WATER TEMP, OIL TEMP, OIL PRESSURE and VOLT GAUGES
£65
All prices include UK delivery.
Will do the lot for £150.
It's Evolution Baby!
| posted on 12/1/11 at 03:58 PM |
Also have an 'A-Frame' for a De-Dion Caterham. Unused.
£72 + delivery from the factory.
... or £25 UK delivered from me!
DIY Si
| posted on 12/1/11 at 05:43 PM |
Can you measure the A frame please? If it's close to what I need for my Sprite, I'll have that.
I need the width across the chassis mounts and how long it is front to back, if you see what I mean.
Sun Tzu, The Art of War
| posted on 12/1/11 at 07:37 PM |
The approximate dimensions are:
925mm (Outer edge to outer edge of long mount)
95mm (Outer edge to outer edge of short mount)
500mm (Depth)
Cheers.
Scotty
DIY Si
| posted on 13/1/11 at 08:54 AM |
Excellent, that's just about perfect that is! So where would you like the money sent to?
bimbleuk
| posted on 13/1/11 at 09:04 AM |
Hi
I've sent a U2U regarding the
VDO WATER TEMP, OIL TEMP, OIL PRESSURE and VOLT GAUGES for £65
| posted on 13/1/11 at 09:14 AM |
U2U's 2U's!
| posted on 13/1/11 at 10:44 AM |
VDO WATER TEMP, OIL TEMP, OIL PRESSURE and VOLT GAUGES - SOLD!
| posted on 13/1/11 at 06:13 PM |
Also have a Nissens 65163A Aluminium Polo Rad for sale. Never been used, or even fitted.
The small plastic bleed inlet / outlet has, however, snapped off. Not a problem as I understand - glue and a self-tapper should seal it nicely!
£18 UK delivered!
Brooky
| posted on 14/1/11 at 07:13 AM |
Hi, dibs on the rad if it's still there.
Cheers.
| posted on 14/1/11 at 08:56 AM |
Sure... U2U on its way!
| posted on 24/1/11 at 10:12 AM |
Just the Caterham Speedo and the VDO Tacho left.
Any offers before eBay?
