redscamp
posted on 16/1/11 at 01:11 AM |
Steel flywheel
About 10 years ago i bought a steel flywheel for a mini
ive had it so long i forgot if it was for a pre-engaged or inertia starter.
when i went to the mini spares website to find out
the site stated that steel flywheels were not balanced.
my question is do steel flywheels need balanced? (standard rev limit)
snapper
posted on 16/1/11 at 08:06 AM |
I would have though the thinking behind NOT balancing at manufacture was that the crank, flywheel and clutch cover would be balanced together,
drilling weight out of the flywheel to achieve most of the balancing
I eat to survive
I drink to forget
MakeEverything
posted on 16/1/11 at 10:13 AM |
Ditto, though i dont think they used the clutch cover at manufacture as these are balanced on their own.
Check the flywheel for marks. If you have the engine it came off, then the end of the crank will have a mark as well, where the two should mate.
Kindest Regards,
Richard.
