Yorkie
posted on 17/1/11 at 02:11 PM |
Air filter advice.
I would like to fit a dome or box filter probably from the Pipercross PX500 or PX600 range but need to understand how to do it and what filter to
buy.
The carbs have the original back plate fitted, do I remove this or bolt directly to it?
Can I remove or replace the trumpets? They are rubber and sit 80mm above the plate which means I would need the deepest filter. (100mm internal
height)
Cheers.
big-vee-twin
posted on 17/1/11 at 04:56 PM |
Hi Mate,
I am planning to use ITG filters simial to Piper, they do an aluminium blank backplate that you cut/drill to suit your layout then the filter bolts on
to it.
You also need to keep the trumpets as these will effect the HP as they smooth out air flow, you could replace them with some billet one's if you
fancied it.
Bikes tend to have two short ones and two long ones to even out the HP as one type gives low down hp and the others give top end HP cant remember
which does which.
Think on a car you can equalise them, there is a formula to work out the length, think it aproximates to 200mm from the valve seat to the entrance of
the trumpet
Hope that helps a bit, someone with more knowledge will be along I'm sure.
Hopeyoue keeping good
Kev
http://www.triangleltd.com
