Author: Subject: 4AGE Cooling Circuit.
Rosco
posted on 19/1/11 at 09:00 PM Reply With Quote
Can anyone help provide a good descrption or diagram for a 4 AGE cooling circuit. I have the Haynes manual but it doesn't answer all my questions. In particular:
Where to connect the heater matrix?
How/ where to connect the expansion tank?
Do I need a valve in the loop for the heater matrix?
Note that I'm using the thermostat.
tul214
posted on 19/1/11 at 09:20 PM Reply With Quote
This was mine before I took the heater out
Existing plumbing
Existing plumbing
Mine did not have the thermostat in though.
1.6 Raw Super6 sold
tul214
posted on 21/1/11 at 06:20 AM Reply With Quote
old rad
old rad
you can see the large top hose on the left and the smaller pipe on the right (shown blue above) that goes off to the top of the header tank(golf mk2)
The 2 red hoses go to the bottom of the Tiger rad. The tiger rad had an inlet at the bottom left and in the middle of the bottom tank. When I swapped to the polo rad (only 1 outlet) I put in copper 'T' in the bottom hose so the middle hose went back up to the bottom of the header tank
bottom hose plumbing
let me know if you need anything else
Mark
[Edited on 21/1/11 by tul214]
1.6 Raw Super6 sold
