Author: Subject: Clutch on the tin top
The Baron
posted on 20/1/11 at 05:19 PM Reply With Quote
I have got a 04 Honda civic type r as my daily drive, which I cant fault, although lately it feels like the clutch needs adjusting, as it doesn’t feel like its fully disengaging when depressed, it doesn’t slip or any thing like than, it just feels like it needs an extra inch of travel.
For the life of me, I cant see how to adjust this dammed hydraulic thing, any one done a job like this on a civic?....
I love my old type 9 with the clutch cable
steve m
posted on 20/1/11 at 05:31 PM Reply With Quote
I am not sure you can adjust a hydrolic system
Maybe a bleed with new fluid would restore it ?
[Edited on 20/1/11 by steve m]
speedyxjs
This may be a stupid question, but a) is there enough fluid in the reservior? and b) have you tried bleeding it?
The Baron
posted on 20/1/11 at 05:32 PM Reply With Quote
cant see any signs of leaking, fuild is up to the lines, it may the fluid is old i guess
pgtips
posted on 20/1/11 at 07:31 PM Reply With Quote
You cannot adjust the hydro clutch I am affraid. The system is a sealed system. If there is low on fluid you could be having a leak from the master or slave cylinder.
Most likely the clutch is worn, the plate is worn or the springs on the plate are failing.
If I die, my biggest fear is that my wife sells all my toys for the price I told her I bought them for...
DRC INDY 7
posted on 20/1/11 at 08:51 PM Reply With Quote
Have a look at the clutch pedal because if it has the same system as nissans then the clutch pedal free play may need re setting
Puddle Dodgers Club
