New Topic New Reply
Author: Subject: Lotus chassis RAL codes?
goodguydrew
posted on 22/1/11 at 06:44 PM Reply With Quote
Where can I find the RAL code(s) for the early Lotus 7 chassis?
Bare
posted on 23/2/11 at 05:38 AM Reply With Quote
what? is a RAL code?
MikeCapon
posted on 23/2/11 at 08:12 AM Reply With Quote
Click me to find out
Bare
posted on 24/2/11 at 04:51 PM Reply With Quote
ral code ?
Ahhhh.. thank you :-)
tul214
posted on 24/2/11 at 05:07 PM Reply With Quote
A quick search found BS 381 671...here
1.6 Raw Super6 sold
Mike Wood
posted on 27/2/11 at 08:14 PM Reply With Quote
Arch Motors the - Lotus & Caterham chassis manufacturers until recently - are still in business, might be worth an e-mail.
As has been said, light grey enamel metal paint following aircraft practice was standard racing car practice, to allow easy crack detection on a brazed steel tube chassis. Not sure if Lotus would have wanted their contractors to have gone for expensive aircraft paint, but standard domestic grey metal paint was around at the time. I do remember one of the Lotus history books ominously referring to Jenolite being used sometimes on chassis that had been stored outside!
Probably the closest you will get to orginal type of paint is handpainting Tekaloid Enamel, see colours: http://www.stephen.hull.btinternet.co.uk/bs381c.html and ordering info: http://www.stephen.hull.btinternet.co.uk/order.html
If you want to get aircraft paint for a tube chassis in the UK, there are a number of suppliers including LAS Aerospace - http://www.lasaero.com/site/products/article?id=P04AG8G7P (Randolph US aircraft paints, not sure of you can get UK stuff anymore!); also try: http://www.skysportengineering.co.uk/ For international try Aircraft Spruce & Speciality: http://www.aircraftspruce.com/intlreps.html
Mike
Mike Wood
posted on 28/2/11 at 03:21 PM Reply With Quote
Mike
See also pic: http://www.andywiltshire.com/other_products.htm
Mike Wood
posted on 28/2/11 at 03:47 PM Reply With Quote
Hi
Have you got more info on your project 'Shortened Book Chassis 1.3 Crossflow' - is this some trials special, or an early Lotus replica as you are asking about Lotus paint codes? Sounds interesting.
Mike
se7en
posted on 28/2/11 at 05:18 PM Reply With Quote
Hi Mike
You are right about the colour of the paint.
When I worked at RNAY, we repaired military aircraft. Because of my interest in motor racing I spent quite a lot of my spare time around a local garage. It just so happened that this garage had two Lotus 48 cars. One of the 48's got smashed at Thruxton and I assisted in the repair by obtaining cleco style panel clips, rivets and some grey paint to match the original.
When they acquired two Lotus 63's they were finished in a similar grey paint. It would not surprise me if the sevens were painted the same.
Tom
New Topic New Reply
