<<  1    2  >>
Author: Subject: Starter Motor Ampage?
Jasongray5
posted on 25/1/11 at 02:12 PM Reply With Quote
Hi guys,
Hows it going?
Ive been searching for a while but cant really get a definative answer or solution, so thought I would post this!
I really want to have my battery completely fused, Just as my starter motor terminal is quite close to my exhaust. 10mm or so. The starter came off of a sierra 2.0DOHC and is turning a zetec 1.8. So does anyone have any Idea what sort of current that would draw? Also, Is there any reason not to put it on the earth side of the battery?
Cheers Jas
How hard can it be?
http://www.flickr.com/photos/33261515@N03/sets/72157611049241239/
MakeEverything
posted on 25/1/11 at 02:24 PM Reply With Quote
Maximum current would be about 30A i would imagine. The starter needs to have the positive supply, as it earths through its chassis.
Kindest Regards,
Richard.
SPYDER
posted on 25/1/11 at 02:35 PM Reply With Quote
I'd be surprised if it was less than 100 amps and more likely a lot more especially with a cold engine.
Geoff
r1_pete
posted on 25/1/11 at 02:44 PM Reply With Quote
Here you go, the spike it getting the engine turning, then it evens out at about 180 amps continuous cranking.
This is a mid range petrol engine, diesels, larger/smaller, higher performance, etc. all have a bearing, but it gives you an idea of the profile.
coyoteboy
posted on 25/1/11 at 02:50 PM Reply With Quote
100A slow-blow fuse on my low compression petrol starter feed.
Jasongray5
posted on 25/1/11 at 03:06 PM Reply With Quote
Cheers for all your replies guys,
Do you think a 250A Maxi fuse on the earth lead would do the trick?
Cheers again, Jas
How hard can it be?
SPYDER
posted on 25/1/11 at 03:13 PM Reply With Quote
250A might well be OK but it could get very hot so be careful where you site it!
Geoff.
r1_pete
posted on 25/1/11 at 03:29 PM Reply With Quote
Do you need a fuse in there? genuine question, my modern cars get main stealer maintained so I don't even lift the bonnet that often, I play with a 67 E Type which certainly doesn't have such a fuse.....
blakep82
posted on 25/1/11 at 03:39 PM Reply With Quote
didn't think they were fused on any car?
________________________
posted on 25/1/11 at 03:51 PM Reply With Quote
Fuse for 200a amps in an arctic weather cold start situation the Pinto starter isn't exactly the efficient compared to modern geared units.
In normal starts it will probably only peak at 100 amps for a very short duration.
On older cars this lead was never fused and never caused problems only modern cars have them.
If you do fit a fuse it will have to be fitted in the main feed from the battery to be effective.
Jasongray5
posted on 25/1/11 at 04:26 PM Reply With Quote
Its only because of how close it is to the exhaust that I thought it might be a good plan to fuse it, so if ever the exhaust was knocked, the fuse would blow, instead of the battery (and car) catching fire?
How hard can it be?
big-vee-twin
posted on 25/1/11 at 04:42 PM Reply With Quote
If you fuse the negative you should really fuse the positive too, shouldnt fuse negative alone.
http://www.triangleltd.com
posted on 25/1/11 at 05:52 PM Reply With Quote
Starter motors take a mahusive amount of electricty to build up the magnetic fields and a slightly smaller amount of power to turn. They're good on grunt, rubbish on efficiency.
However they are simple and only used for short periods hence no problem.
But if you put a fuse making it a big'un as already mentioned.
Neville Jones
posted on 27/1/11 at 11:15 AM Reply With Quote
Starters on most engines, new or old, put out about 2~3hp, and more.
Do the maths. 2hp~1500watts. =125amps 3hp~190amps
As the graph above shows, startup can spike at up to 4 times turning current.
The above is from personal experience, and measured using accredited equipment, not from i'net or wiki searches!
posted on 27/1/11 at 06:41 PM Reply With Quote
Put a heatshield between the starter and exhaust with a bit of wrap around the cable . Will cause more problems than it's worth fitting a fuse
ashg
posted on 27/1/11 at 07:21 PM Reply With Quote
having a fuse on the negative side is as good as not having a fuse at all.
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
alawrence
posted on 27/1/11 at 09:05 PM Reply With Quote
Why Ash ?
nz_climber
posted on 28/1/11 at 10:51 PM Reply With Quote
This is just plain wrong! I think you will find alot of vehicle DC systems are switched earths, doesn't mean the switch doesn't work.. A fuse is exactly the same.
Although standard practice is to put a fuse as close to the source as possible, in this case it would work fine on the negative. But personally I would put it on the positive side, and also would use a motor rated circuit breaking (means you can reset it if it does trip)
Remember current on the -ve side will be equal to the current on the +ve side of the battery
http://aarons7.wordpress.com
posted on 29/1/11 at 09:13 AM Reply With Quote
Probably the main reason for fitting a fuse on the positive is safety, putting a fuse on the negative is a bit like shutting the stable door after the horse has bolted
alawrence
posted on 29/1/11 at 10:24 AM Reply With Quote
why ? Ash
[Edited on 29/1/11 by alawrence]
alawrence
posted on 29/1/11 at 10:41 AM Reply With Quote
I agree..
In fact , when working on large dc systems and also automotive systems it is always safer to isolate the negative 1st.
there is always the possibillity that when disconnecting the pos first you can slip and put your spanner or lead to earth with a shocking outcome (on neg earth systems )
posted on 29/1/11 at 10:44 AM Reply With Quote
Putting a fuse on the neg leaves a large part of the curcuit unprotected!
Jasongray5
posted on 29/1/11 at 11:31 AM Reply With Quote
How? If it breaks the circuit?
How hard can it be?
alawrence
posted on 29/1/11 at 12:57 PM Reply With Quote
POPPYCOCK !
posted on 30/1/11 at 02:40 PM Reply With Quote
Some people obviously don't know thiere arse from thier elbow!
<<  1    2  >>
