Author: Subject: Spooling a diff
sevaun
posted on 26/1/11 at 08:36 AM Reply With Quote
Spooling a diff
I'm converting my roadgoing bookbuilt chassis to use purely for autotesting. One of the tweeks I'm considering is welding/ locking/spooling the diff to get more traction without the expense of a LSD. Does anyone have any experience of driving a car with a locked diff, particularly in autotesting or similar?
Richard
carpmart
posted on 26/1/11 at 08:52 AM Reply With Quote
My race car has no differential so is a locked diff. It's an enhanced driving style you will have to learn in effect you need to induce oversteer and then control it to get round corners. It will feel like you have loads of understeer but that is because the back really pushes through the front of the car. (not sure that makes sense as it is poorly articulated! ) The set-up with no diff is very predictable so inspires confidence to get the back end out.
HTH?
'94 MX5 MK1, 1.8
F10 M5 - 600bhp Daily Hack
Mercedes A class - Son's Car
sevaun
posted on 26/1/11 at 09:58 AM Reply With Quote
HTH?
mmmm.. understeer might be a problem in tight situations on an autotest course, but like you say once the backs out it should be more controllable.
Richard
carpmart
posted on 26/1/11 at 10:53 AM Reply With Quote
I don't think locking the diff actually reduce front grip, it just feels like it does!
'94 MX5 MK1, 1.8
Nash
posted on 26/1/11 at 11:09 AM Reply With Quote
I used to race an F2 BRISA Stockcar a gazzillion years ago with a welded diff. I wouldn't think it would be useful in Autotesting as it is less agile / nimble then a stock diff.
Is it something common they do in Autotesting or are you looking at it as an inovation?
.............. Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
sevaun
posted on 26/1/11 at 12:46 PM Reply With Quote
.............. Neil
Inovation really. probably won't make a great deal of difference on small tight layouts, but on long fast sections it could be useful for getting traction down after a manouvre. Also we'll be doing some grass autotesting where a locked or lsd would be very useful.
Richard
Doctor Derek Doctors
posted on 26/1/11 at 12:55 PM Reply With Quote
They're fine in the dry but absolutely useless in the wet and downright dangerous on a wet road.
Liam
posted on 26/1/11 at 07:10 PM Reply With Quote
I would have thought in autotest more time is to be saved in the twisty bits (the whole course?) than 'long fast sections' (do they exist?) where you wouldn't want to be giving yourself extra understeer. But then if you have the torque to wheel-spin on demand, maybe a welded diff's a good thing?
Best answer is to just ask this guy what he's using and go for that...
http://www.youtube.com/watch?v=3Rhz19ZrpZg
Neville Jones
posted on 27/1/11 at 11:07 AM Reply With Quote
Autotesting needs tight turning and agility. The exact opposite of what a 'spooled' or locked diff will give you. You need to be able to turn in easily and quickly, and get drive out of the turns. The locked diff WILL give you attrocious turn in push, and violent power reactions, especially on the tarmac most of these events are held on.
Innovative? No, not really. It's been done and found severely wanting.
What you need is a very good lsd, set up to your style. Viscous don't do the job for this either.
Nev.
sevaun
posted on 27/1/11 at 02:44 PM Reply With Quote
Sound Advice
That sounds very sensible advice and from someone who's been there.
Come to think of it that also applies to my other project at the moment. I've stripped my bike engined single seat hillclimber for a winter overhaul. I discovered it runs an open (fiesta)diff, whereas I was led to believe it was LSD. Your comments about viscous LSDs answers a thought I had about fitting an Escort RS turbo viscous LSD. The car already tends to understeer and from what you say a viscous diff would probably make the situation even worse.
Thanks Nev
Richard
[Edited on 27/1/11 by sevaun]
Uphill Racer
posted on 27/1/11 at 10:31 PM Reply With Quote
This is worth looking at.
http://www.phantomgrip.com/
posted on 31/1/11 at 01:01 PM Reply With Quote
All sounds a bit like snake oil to me. No pics of the internals or any real engineering info.
Not having a list of fitments or prices doesn't really help either. A shame as it coul;d be a decent bit of kit.
Kriss
posted on 31/1/11 at 01:37 PM Reply With Quote
I have had a play with a pinto Indy with welded diff and it was terrible.
So much understeer (certainly what it felt like from the rear)
I can kick the back end out in my LSD indy and do nut, figure of eight do nut etc, but not a chance with the welded diff, just felt totally unconnected and horrible.
Would think in the wet or grass would be even worse.
get a 3.62 sierra lsd for less than £300?
Richard Quinn
posted on 31/1/11 at 01:55 PM Reply With Quote
There are a few clues on the "installation instructions" page HERE I think I'll keep my wallet in my pocket for now.
daviep
posted on 31/1/11 at 02:04 PM Reply With Quote
Looks like a housing with some strong springs to exert pressure between the planet gears, not going to be very healthy for the thrust washers behind the planet gears.
loggyboy
posted on 31/1/11 at 02:09 PM Reply With Quote
To make use of a welded diff you;d have to be pretty much constantly sideways, opposite lock to opposite lock. You might get that on an Autosolo, but defo not at an Autotest.
blakep82
posted on 31/1/11 at 02:59 PM Reply With Quote
terrible idea IMO. ok for drifiting and drag racing i guess, but anything involving corners (without both wheels smoking) it will be pretty hopeless
________________________
Uphill Racer
posted on 3/2/11 at 12:35 AM Reply With Quote
The springs need only be 'strong' enough to try to provide a rotational force against the spider gears. I love its simplicity and the testimonials look good.
blakep82
posted on 3/2/11 at 01:28 AM Reply With Quote
i'm sure if i wanted to sell people something that doesn't work, i could write a few good testimonials
Uphill Racer
posted on 3/2/11 at 01:41 AM Reply With Quote
Well I thought the concept was good, can you explain to me why it wouldn't work?
blakep82
posted on 3/2/11 at 02:15 AM Reply With Quote
well, looking at it, it appears to be a small box containing springs, which pushes against the side gears in an open diff giving some resistance.
have a look at this, its an exploded diagram of a plate type LSD
it also features a plate inside with springs acting on the side gears, but the side gears are forced onto clutch plates which locks the gear against the diff case.
without those clutch plates, what does it lock the gears onto? onto a thrust washer basically, or an oiled up shim. and if it was that easy, why do tran-x, quaife and others bother with the plates?
i produced a small magnet which is glued on the side of an axle, pulling the gears out (rather than pushing them like on normal LSD set ups) here's some testimonials
dave, oxford
i was sceptical on how a system half the price of normal LSDs could work, but i stuck the magnets to the side of sierra diff as shown in the instructions. all i can say is WOW my cars handling has been completely transformed! on hard acceleration, my car used to just spin the right hand wheel, but now i can drift my car round roundabouts! its amazing.
keving, doncaster
i fitted this to my skyline in minutes. i couldn't beleive how easy the instructions were to follow. the device was fitted in minutes, without all the expensive set up normally needed for the usual LSDs. best £200 i've ever spent!
you get the idea... testimonials mean nothing really
