Author: Subject: Type 9 Bellhousings
Fishface
posted on 27/1/11 at 05:49 PM Reply With Quote
Type 9 Bellhousings
With the problems im having trying to get a starter to fit my 1.8 silvertop/type 9 gearbox im beginning to wonder if there are variations in the bellhousing. I have a feeling when i picked up the type 9 from the scrappy it had 1.8cvh written on the gearbox. Could this be my problem???? Seems to fit to the zetec fine!
big_wasa
posted on 27/1/11 at 05:55 PM Reply With Quote
No that will make no odds. Whats the problem ?
Some starters are chunkier than others. On a silver top you will need to grind a little of the webbing away for it to fit and on a black top you have to hack no end of.
What starter have you got ?
lewis
posted on 27/1/11 at 06:17 PM Reply With Quote
I have just been doing this job on my blacktop and have had to cut alot of the fins away,pretty drastic but just do a bit at a time & keep checking
The Baron
posted on 27/1/11 at 06:51 PM Reply With Quote
A lucus LRS707 is the starter for a silver top on a type9, with a light grind on the sump.
B
Fishface
posted on 27/1/11 at 08:34 PM Reply With Quote
Ive had two so far a LRS0707 and a quinton hazel one that was equivalent of the LR567. The first one was way too small and didnt seem to extend far enough to engage and the second the holes didnt line up at all. Im wondering whether the LRS0707 may be wrong. I asked for one for an 88 sierra 1.8 starter but didnt seem to work. Ive had loads of trouble as the motor factors have struggled with the codes and lucas parts. Will try another one and go for LR707.
posted on 27/1/11 at 08:41 PM Reply With Quote
LRS707 on my 1.8, no chopping required..
posted on 27/1/11 at 09:48 PM Reply With Quote
No need to post pics of the balcktop mod! He asked about a 1.8 silvertop....
austin man
posted on 27/1/11 at 09:59 PM Reply With Quote
fitted the 1.8 cvh starter to mine, hd to cut a section out of the sump as it wasnt allowing the starter to sit square causing a problem with engagement. So cut a section away and had a plate weldedinside the sum to seal the hole. Sorry no pics at present
jacko
posted on 27/1/11 at 10:06 PM Reply With Quote
Sorry i have deleted the photo i put up
