New Topic New Reply
Author: Subject: BEC Bump and Droop for a Race Car
Doctor Derek Doctors
posted on 31/1/11 at 01:08 PM Reply With Quote
With my background being in the world of 1+ Ton Tin Top races I'm not experienced in suspension settings for BEC race cars.
Can anyone tell me roughly how much droop (if any) I should build into the suspension and how much movement I should realistically allow for in bump?
This will be a rose-jointed RGB race car with no concessions for road use. Usually I'd start with Zero droop but like I said 7's are new to me.
kb58
posted on 31/1/11 at 03:14 PM Reply With Quote
I'd go 1" droop and whatever's left over for compression. Because you didn't specify ride-height, wheel rates, and whether the car has tunnels and wings, it's hard to be helpful.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
posted on 31/1/11 at 03:30 PM Reply With Quote
Ride height will be as close to 75mm as I can get (RGB Min)
No Wings, maybe some minor ground effects but nothing significant (RGB is supposedly non-aero)
kb58
posted on 31/1/11 at 04:06 PM Reply With Quote
Then I'd vote for 25mm droop, 50mm compression, with an additional 12mm for a rubber bump-stop. This leaves out what your expected spring rates are but I'm assuming you'd work that out in reverse off the expected track loads.
(I'm in the US so am unfamilar with your RGB series.)
[Edited on 1/31/11 by kb58]
posted on 31/1/11 at 06:58 PM Reply With Quote
Pretty much what I was thinking (50mm Bump) maybe a little more droop than I was expecting but then 1100KG Porsches are a whole other ball game.
procomp
posted on 1/2/11 at 04:47 PM Reply With Quote
Hi
1" is fine for front end but rear will require 1 1/2" obviously all dependent on your wheel to rod ratio.
Cheers Matt
posted on 2/2/11 at 12:29 PM Reply With Quote
Originally posted by procomp
Hi
Cheers Matt
The next question then (that I forgot to ask originally) is: What would be the target for the neutral camber settings? I.E when I build the car what should the camber be (front and rear) when the camber adjusters are set to the mid point?
I was thinking around 2.5 degrees (front) and 1.5 degrees on the rear.
kb58
posted on 2/2/11 at 02:29 PM Reply With Quote
Depends on the type and width of the tires, as the wider they are the less camber change they can deal with. OTOH, some tires are made for just that purpose, so it "depends." It also depends how the car's used. Drag-racing only, zero camber change. Tight road-race, a fair amount. Long more open road-races, somewhere in the middle. That said, it all tends to even out, as one car will do better in on part of the track and another car that's set up different will do better elsewhere, but the laptimes will be very close.
There won't be any black-and-white answers to this stuff.
[Edited on 2/2/11 by kb58]
posted on 2/2/11 at 05:01 PM Reply With Quote
well that why I specifically asked for base target figures for a 7' competing in the RGB series.
Also you appear to have completely misunderstood the question and starting talking about camber change during suspension movement, which was not what I was asking.
I am after the base figures for the camber when the camber adjusters are set in a central position. Although I apreciate that this will depend somewhat on the amout of adjustment I have (which I will work out at the weekend).
Ian-B
posted on 2/2/11 at 06:34 PM Reply With Quote
My RGB car ran using slightly less droop and bump travel than is being quoted above, but that is with running wheel rates in the region of 2.7-2.9Hz (this stiffness was not in order to reduce suspension travel).
The car ran approx 1.2 degree of camber, but this will vary dependant on your suspension geometry combined with roll stiffness and suspension system stiffness.
Ian
kb58
posted on 2/2/11 at 08:15 PM Reply With Quote
Originally posted by Doctor Derek Doctors
...well that why I specifically asked for base target figures for a 7' competing in the RGB series. Also you appear to have completely misunderstood the question and starting talking about camber change during suspension movement, which was not what I was asking...
Well how can anyone give answers to questions when large areas of your suspension design are unknowns? I included camber-gain as part of my answer because, well, you didn't. Given that I don't know what you have, how can I possibly give anything more concrete than vague guidance, since it's based upon vague information. I'm sorry you're disappointed I can't provide black-and-white answers, but that's what you get when providing an enigma for a data set. About all you can hope for is that someone with an identical car pops in here and is willing to share his secrets.
posted on 2/2/11 at 08:26 PM Reply With Quote
Yawn.....
Alan B
posted on 2/2/11 at 08:54 PM Reply With Quote
Yawn.....
Uncalled for and rude......not the best way to get help from someone....
MikeFellows
posted on 2/2/11 at 09:03 PM Reply With Quote
I've no idea what any of you are talking about
but it seems to me you had someone who did know what they were talking about and you pretty much told them to wee off. I cant image anyone's cueing up to reply to you now.
[Edited on 2/2/11 by MikeFellows]
daniel mason
posted on 2/2/11 at 09:09 PM Reply With Quote
not the first time is it!
Richard Quinn
posted on 2/2/11 at 09:37 PM Reply With Quote
I've noticed a bit of a trend too. Have you tried asking your questions HERE? Although, I would hazard a guess that as your car is a one off, you will struggle to get anything more specific than given above. One of the joys of being at the cutting edge I'm afraid.
daniel mason
posted on 2/2/11 at 10:45 PM Reply With Quote
how do you mean a one off? its standard mnr chassis! engine is slightly different though. was refering to op being rude. he said i couldn't read the other day! lol
Richard Quinn
posted on 2/2/11 at 11:02 PM Reply With Quote
Sorry, I was agreeing with you that it wasn't the first time that there had been a response like that from the OP and that I'd noticed the trend. The second part was aimed at pointing the OP in the direction of the RGB Forum and my comment about a one-off was regarding his chassis not yours Daniel. Sorry, could've been clearer (it's been a long week already!)
daniel mason
posted on 2/2/11 at 11:08 PM Reply With Quote
no probs mate. have a beer and cheer up! lol
posted on 3/2/11 at 12:49 PM Reply With Quote
Actually if you read that thread I was AGREEING with you and apologised and cleared up the misunderstanding.
As said it was a very simple question about were people running 7' race cars place their neutral camber position. Not in any way a question about camber change in bump and roll.
On the other thread I pointed out that it wasn't an MNR and Mr Mason kindly pointed out were the chassis came from but then a load of people failed to read any of the thread and started going round in circles.
I really don't understand why people feel the need to right a load of stuff without actually reading the original post or the existing answers. Its the sort of 4Chan level banality that ruins forums.
Richard Quinn
posted on 3/2/11 at 01:36 PM Reply With Quote
But would that not depend on how much camber your particular set up and chassis needs in the first place? If it's going to need about 2.5 degrees on the front to start with then this would be a good place for the adjustors to be centred around. If you think it will be between 2 and 3 degrees, centre it on 2.5 (assuming you can adjust by more than 0.5 either way). How much camber do you think you will be running and how much adjustment do the adjustors give?
New Topic New Reply
