Author: Subject: Must have tools?
theduck
posted on 31/1/11 at 10:19 PM Reply With Quote
Must have tools?
Just wondered what everyones must have tools for building a kit car are? I ask as I am still building my tool collection at the moment, and have a few ideas of things I want/need and thought a thread like this could be useful for those starting out.
RichardK
posted on 31/1/11 at 10:25 PM Reply With Quote
Angle Grinder has got to be the number 1!
Gallery updated 11/01/2011
Tatey
posted on 31/1/11 at 10:26 PM Reply With Quote
MIG welder
The trusty rubber mallet
Ratchet spanner set
Decent socket set
kipper
posted on 31/1/11 at 10:30 PM Reply With Quote
must have things
Garage heater,Kettle.
Regards Denis.
Where did that go?
Paradoxia0
posted on 31/1/11 at 10:31 PM Reply With Quote
Hammer
Drill
Hand Rivet Gun
Rivnut gun?
Screwdrivers
Hammer
Wirecutters/Pliers
Hammer
There is no replacement for displacement...
mookaloid
posted on 31/1/11 at 10:32 PM Reply With Quote
twisted wire cup brush for angry grinder and good electric drill
UncleFista
posted on 31/1/11 at 10:35 PM Reply With Quote
At least 2 angle grinders, with different discs on. Saves changing from cutting to grinding then back again umpteen times a day
Tony Bond / UncleFista
MikeR
posted on 31/1/11 at 10:41 PM Reply With Quote
I've got three angry grinders - except they keep twisting the power leads. I now have them on different plugs one to the left, one to the right and one in the middle of hte garage ....... they still get twisted. You can't have too many angry (oh ok, angle) grinders, plugs and lights in a garage.
liam.mccaffrey
posted on 31/1/11 at 10:47 PM Reply With Quote
I can't think of anything that I use more than an angle grinder, and a selection of the correct hammers I have about 12 hammers I regularly use
Build Blog
Build Photo Album
MikeR
posted on 31/1/11 at 11:22 PM Reply With Quote
some magnetic blocks for holding stuff before welding, a auto darkening welding mask, some screwdrivers, scribes, auto punches, pillar drill, screwdrivers to use as chisels.
somewhere to go that isn't the garage when you've had enough
handyandy
posted on 31/1/11 at 11:26 PM Reply With Quote
Ok ok, these are not tools.....but safety goggles & decent work gloves are a must
& yes, the angry grinder is a very useful tool
I,ve gone through 3 of them in 14 months ( cheap enough to replace tho )
The suggestion of having 2 available is a very good one,
cheers
andy
monkeyarms
posted on 1/2/11 at 08:28 AM Reply With Quote
A good sturdy work bench with a big vice.
A wooly hat!
Not a must have but nice is a DAB radio.
Daddylonglegs
posted on 1/2/11 at 08:29 AM Reply With Quote
THIS FORUM!
whitestu
posted on 1/2/11 at 08:32 AM Reply With Quote
Latex gloves so you can do half an hours work without spending the rest of the day getting oil off your hands.
matt_gsxr
posted on 1/2/11 at 08:37 AM Reply With Quote
not essential, but once you have had them you wouldn't give them up
90deg adapter for drill
B&D power file
dave-69isit
posted on 1/2/11 at 09:35 AM Reply With Quote
motivation and loads off space to hide ur bits a chalk board ( helps to put ur list off to do or not to do yet )
r1_pete
posted on 1/2/11 at 10:55 AM Reply With Quote
After 35 years working on cars bikes juke boxes.... I've built quite a sizable toolkit and can't think of anything I'd be without, the selection of air ratchets are probably the biggest labour savers.
Alan B
posted on 1/2/11 at 06:10 PM Reply With Quote
Thinking back about 20 years or so and comparing to today I'd say that digital cameras and computers have been a major boost to the hobby. Not car building tools per se but invaluble nonetheless.....
Alan
hughpinder
posted on 2/2/11 at 01:23 PM Reply With Quote
If you're building the chassis:
a welder
hacksaw
angle grinder with grinding, cutting and flap disks
some clamps and magnetic holders
mole grips
Bench and vice
18V drill, drill bits
rivet gun
half round file
chain hoist and a girder inthe right place, or an engine hoist bloody useful
decent set square and tampe measure
build stands
wire brushes for cleaning things
If youre buying used bits to refurbish, rather than new as you're ready for them, a stack of used metal shelving is good to have. Also, if you plan to do some of the design yourself, you'll probably aquire some stuff just so you can measure it!
Assembling the car:
All the usual car serviceing tools
socket set
spanners
flat + cross point scredriver
pliers
soft faced hammer+ 2kg lump hammer
crimping tool, wire strippers, side cutters, soledring iron
... this list goes on as long as you want - circlip pliers, torque wrenches, splined bits.....
Regards
Hugh
blakep82
posted on 2/2/11 at 02:15 PM Reply With Quote
can't think of any one particular tool i find more useful than the rest, good socket set and rachets are the most used i guess, but no good for welding a chassis together or lifting an engine out.
engine crane is possibly the most useful so far? no, grinder! or jack and axle stands? don't know really
________________________
Ivan
posted on 2/2/11 at 02:58 PM Reply With Quote
An accurate tape measure is vital - oh and an angle grinder +2 as others have said. Drill press is handy as well plus cut off saw.
Confused but excited.
posted on 2/2/11 at 04:22 PM Reply With Quote
Must have Flap Wheels to go with the angry grinder.
I have only just, despite my years, discovered the joy of flap wheels. Now the No1 fan.
