Author: Subject: FS (free) laminated flooring tbd
Humbug
posted on 9/2/11 at 08:52 AM Reply With Quote
Not sure if there is any market for this, but we are getting wood flooring put down in a couple of months, so will be taking up the old laminate flooring, which has the odd chip, etc. but there is lots that is perfectly usable.
There are two sections, both the click-together type:
1. Wood effect - each board has three narrow strips of light wood-type finish
2. Tile effect - each board looks like a series of slatey blue-grey tiles
So - question: should I just dump the old flooring, board out the garage/shed or give it to someone?
The simplest would be to load it up and take it to the dump but my Locost mentality tells me that it would be a shame if someone couldn't make use of it
emsfactory
posted on 9/2/11 at 09:02 AM Reply With Quote
Put it in the garage?
easier to sweep than carpet.
Daddylonglegs
posted on 9/2/11 at 09:30 AM Reply With Quote
You read my mind
posted on 9/2/11 at 09:44 AM Reply With Quote
Another vote for slapping it down in the garage - very easy to keep clean and tiday and if you bung some insulation underneath then more comfy than concrete too.
