Author: Subject: Oops
neilp1
posted on 9/2/11 at 07:20 PM Reply With Quote
Oops
Well, I've just managed to round off one of the flywheel bolts on my Duratec engine. I got the rest out so just the one. Any ideas on the best way to get it out.
By the way the flywheel is scrap as I will need a different one!! so if it gets damaged it wont matter
Cheers in advance,
Neil
steve m
posted on 9/2/11 at 07:22 PM Reply With Quote
A big chisel, and even bigger mallet!
mookaloid
posted on 9/2/11 at 07:23 PM Reply With Quote
A six sided socket should do the trick if you rounded it off with a 12 sided one. Failing that a hammer and cold chisel might loosen it.
russbost
posted on 9/2/11 at 07:24 PM Reply With Quote
air chisel or failing that a chisel in an sds hammer drill
RichardK
posted on 9/2/11 at 07:25 PM Reply With Quote
Can you get a set of stilsons in?
Gallery updated 11/01/2011
easisatman
posted on 9/2/11 at 07:27 PM Reply With Quote
Give it a good clout on the face of the bolt and try mole grips to turn or hammer a smaller socket on
hope this helps
regards
Paul
posted on 9/2/11 at 07:28 PM Reply With Quote
Weld on a nut Always does the job for me!
plentywahalla
posted on 9/2/11 at 07:32 PM Reply With Quote
BenB beat me to it .... weld a bar on, or a nut. The heat from welding will often crack the bolt free, just remember to let it cool completely first.
flak monkey
posted on 9/2/11 at 07:33 PM Reply With Quote
Duratec flywheel bolts are bloody tight! And they have thread lock on, so you wont shock it undone unfortunately.
If you can heat it up you might be able to destroy the threadlock. Needs about 250deg which will make it easier to get undone.
Otherwise, as mentioned, hammer a 6 sided socket on and have a go. Cant make it any worse. Lol....
All else fails weld a bar onto it and hammer it undone using the bar.
Sera
http://www.motosera.com
hillbillyracer
posted on 9/2/11 at 10:11 PM Reply With Quote
One of these in appropriate size:
http://www.amazon.co.uk/IRWIN-Piece-Expansion-Set-16/dp/B0002YVUM6/ref=pd_sxp_grid_pt_0_2
I've got 15 of them to take from 10mm to mabye 27mm, not cheap compared to ordinary sockets & not used much either but they work very well & I've thought them worth every penny when they've got me out of the brown stuff!
Mabye only worth it if you're expecting more of the same in the future
AndyGT
posted on 9/2/11 at 10:43 PM Reply With Quote
Grind off the bolt's head and slide off the flywheel. Then weld on a nut as fore-mentioned. Might be worth grinding a couple of flats on the threads and using a pair of "stilson" pipe grips? That sounds like an expensive job if the bold snaps or becomes too badly damaged!!!
Daddylonglegs
posted on 10/2/11 at 08:08 AM Reply With Quote
Blowtorch, get it nice and warm, then try either the moleys or a 6-sided socket.
neilp1
posted on 10/2/11 at 05:48 PM Reply With Quote
well I tried 6 sided socket, not happening. I'm toying round with drilling the head off the bolt off then once the flywheel is removed getting the stillies on it Or I may try some of them Irwin bolt removers first!!
coyoteboy
posted on 10/2/11 at 06:55 PM Reply With Quote
Grind off the head, remove fly, use grips to remove remaining threaded length.
owelly
posted on 10/2/11 at 07:26 PM Reply With Quote
Soak the bolt in vinegar and rub salt on it. Place a mug of water 900mm away. When the bolt gets thirsty and makes a dash for the water, trap it under another mug. Sorted.
http://www.ppcmag.co.uk
RichardK
posted on 10/2/11 at 09:19 PM Reply With Quote
Xtreme Kermit
posted on 10/2/11 at 09:28 PM Reply With Quote
Class...
