Author: Subject: Sierra Handbrake Cable Joiner/Nipple/Wostsit....
Bumble
posted on 12/2/11 at 09:33 PM Reply With Quote
Wanted........Sierra Rear Caliper Handbrake Cable Joiner/Nipple/Thingy........the type that you can shorten the cable at the caliper and re-fit with 2 grub screws perpendicular to one another. I phoned MK but they don't have any........waiting for some to come in but couldn't say when that would be. Only need the one. Let me know if anyone has one or if there is anywhere else I can get hold of one.
Thanks,
Matt
austin man
posted on 12/2/11 at 09:44 PM Reply With Quote
I used the brass part form a terminal block, tighthened up the screws then soldered it as well no problems
Steve Hignett
posted on 12/2/11 at 10:48 PM Reply With Quote
I've seen people use the brass terminal block items before WITHOUT them failing, but I don't have much faith in them myself for no good reason
Theere used to be an online shop called speed-kartz (or something like that) that sold accessories for race karts and the like. I've used them for all sorts of cable accories like accel. cables and the above needed clamps...
Sorry I can't remember it!
Steve Hignett
posted on 12/2/11 at 10:49 PM Reply With Quote
woohoo, I knew there was a Z in there somewhere!!!
http://www.zoomkarts.com/products.asp?categoryID=8
Ben_Copeland
posted on 12/2/11 at 11:44 PM Reply With Quote
Hmm £10 minimum order!!!
Ben
Locost Map on Google Maps
Enter Your Details Here
Bumble
posted on 13/2/11 at 06:07 AM Reply With Quote
Thanks for the replies so far but I'm actually after the one with the Sierra handbrake pull gland as per the one in my photo archive. Anyone have one or know where to get hold of them?
[img] Sierra Handbrake Cable Gland 1
[/img]
RAYLEE29
posted on 13/2/11 at 08:06 AM Reply With Quote
hi, on mine I cut the cable off and carefully drilled the old cable out of the fitting and then through to the square hole and then soldered it back on to the shortened cable.
it a bit old skool i know and it hasnt been on the road or through iva but you cant tell and ive given it a very good yank to test and it seems to hold.
Ray
mookaloid
posted on 13/2/11 at 08:58 AM Reply With Quote
Don't know for definite but speedycables.com could well have something,
Failing that, I would ring round the various manufacturers who use sierra running gear - ie most of them
DRC INDY 7
posted on 13/2/11 at 11:34 AM Reply With Quote
I just cut the cable near the handbrake lever drilled a hole through a setscrew to pass both cables through then tightened up with a nut and washers a locost way to do it
Puddle Dodgers Club
YQUSTA
posted on 13/2/11 at 12:20 PM Reply With Quote
Have you tried biggred?
You may need to phone them.
"If in doubt flat out"
Colin McRae
Ugg10
posted on 17/12/14 at 01:37 PM Reply With Quote
[/img]
Sorry to ressurect this thread but does anyone have a link to where I can buy this cable end as I need to modify a sierra handbrake cable for disc calipers to go on my Anglia. Google has not been my friend this time :-(
Thanks in advance.
[Edited on 17/12/14 by Ugg10]
1968 Ford Anglia 105e, 1.7 Zetec SE, Mk2 Escort Workd Cup front end, 5 link rear
Build Blog - http://Anglia1968.weebly.com
CosKev3
posted on 17/12/14 at 03:35 PM Reply With Quote
MK sell the ones that are retained by screws.
Or EBay sell solder on ones;
KNOTT TRAILER BRAKE CABLE EYELET CONNECTOR-160x35 203x40 200x50 250x40 torpedo
Ugg10
posted on 17/12/14 at 04:22 PM Reply With Quote
Manythanks, much appreciated.
CosKev3
posted on 18/12/14 at 08:58 AM Reply With Quote
No probs
Stella
posted on 18/12/14 at 03:42 PM Reply With Quote
If you cut off the existing one, drill out the existing crimped cable and then drill a hole thru the shaft, tap it 3mm you have opposing clamps, 2 x 3mm grub screws and you have what you were looking for, Ive done this on 2 Furys and a seven with no issues.
