Author: Subject: Gear Indicator For R1
eddie99
posted on 15/2/11 at 04:32 PM Reply With Quote
Hi Guys,
What gear indicator do people use for the R1? Are there any options? i've got a 1999 4XV, also not using original clocks, not sure whether that makes any difference.
Regards
Ed
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
bitsilly
Contributor
Posts 726
Registered 9/6/05
Member Is Offline
Photo Archive Go!
Building: Flexibility into my marriage, bless her!
posted on 15/2/11 at 04:41 PM Reply With Quote
I don't think there is any mechanical pick up (like a busa). I have been told the only way is calculative, ie using a dash computer which uses number of wheel rotations and engine revs.
Thats why I bought a dash display which could do that!
skydivepaul
posted on 15/2/11 at 04:43 PM Reply With Quote
I used a veypor dash system on mine
was o.k. but it did sometimes struggle to keep up with fast changes
http://www.smartideasuk.com
http://www.smartmapping.co.uk
HD CCTV
IP security systems
access control systems
monkeyracer
posted on 15/2/11 at 04:48 PM Reply With Quote
Is there a gear sensor that displays on the busa dash?
eddie99
posted on 15/2/11 at 04:49 PM Reply With Quote
Also i forgot to add, my car doesnt have a speedo... but an option is to fit a cheap electronic speedo, any ideas??
[Edited on 15/2/11 by eddie99]
posted on 15/2/11 at 06:01 PM Reply With Quote
Healtech GIpro X-Type
Healtech make the best range of gear indicators by far IMHO
Phil
[Edited on 15-2-11 by Hellfire]
angliamotorsport
posted on 15/2/11 at 06:21 PM Reply With Quote
I use a gipro gear indicator on my single seater which has a gsxr engine and has worked ok,
also on some engines it can bypass any limiter a bit if required.
hobbsy
posted on 15/2/11 at 07:20 PM Reply With Quote
This is what I use on my 5PW - should also work on your 4XV?
http://www.acumen-electronics.co.uk/category/Gear_Indicators___Shift_Lights/DG8_Digital_Gear_Indicators_and_Accessories,b.html
Kriss
posted on 16/2/11 at 12:40 PM Reply With Quote
I have the same Acumen on my 5PW with aftermarket dash. Its a little slow (say 20ft to calculate, maybe more) but at least you knwo when to not go for 7th!
andyfiggy2002
posted on 16/2/11 at 05:03 PM Reply With Quote
on the subject anyone found anything that works for a 1993 893cc blade with out an engine pick, all i'm after is a readout that tells me when in 6th as im always reaching for 7th, tried accumen but had mind of its own
[Edited on 16/2/11 by andyfiggy2002]
