Nitrogeno25
posted on 17/2/11 at 01:51 PM |
Soft Tires vs. fatter tires
I'm now running R888 in 14" 185/60 which is the only size available where I live. I'm veyy satisfied with the performance but as
I'm doing lots of road miles I need to get something that last longer.
How can I compare (in terms of grip) a set of Bridgestones potenza in 205/55 or R888 in 185/60?
Thank you very much!
designer
posted on 17/2/11 at 02:19 PM |
Where do you live??
Nitrogeno25
posted on 17/2/11 at 02:21 PM |
quote: Originally posted by designer
Where do you live??
Uruguay, South America And 185/60 14" is the only size I can get in R888!
contaminated
posted on 17/2/11 at 04:24 PM |
Based on my experience it depends whether you want to go round the bend or straight into a ditch! R888s will provide way superior grip. I have a set
of Bridgestones potenza in 205/55 sat in my shed - where thay have been for a while. On a heavier car they are good. On the Tiger they were hopeless
unless you could get them really hot.
HTH
Dan
nz_climber
posted on 18/2/11 at 04:41 AM |
First you need to specify which Potenza's you want to run.. as they range from the Re55s which will be the same if not softer than a toyo R888,
right the way through RE11, RE001, RE040 etc etc..
Saying Potenza's will head you straight into a ditch is very untrue. The RE55S is probably quicker and more grip than a R888 but twice the
price.. Bridgestone have more variation in the Potenza range than some tyre companies have in total.
http://aarons7.wordpress.com
