Author: Subject: Missing on tick over
madteg
posted on 23/2/11 at 07:52 PM Reply With Quote
Thinking of buying Subaru forester that is missing on tick over, what is it most likely to be. Its a 2.0L turbo
[Edited on 23/2/11 by madteg]
slingshot2000
posted on 23/2/11 at 07:57 PM Reply With Quote
It is very likely to be; expensive!
meany
posted on 23/2/11 at 08:24 PM Reply With Quote
What year and model is it?
could be something simple like a coil pack or the maf or the idle speed solenoid..plus many more.
could also be expensive as said.
the early impreza's have some plugs under the steering column (Forester's might be the same)
which when connected together make the engine management light flash in a particular way to show a fault code.
posted on 23/2/11 at 09:14 PM Reply With Quote
Burnt Exhaust valve or valve recession.
If only missing a idle not at higher load & speed it is unlikely to coil pack, plug or other ignition related --- HT ignition faults show up when the engine is under load.
meany
posted on 23/2/11 at 09:19 PM Reply With Quote
also could be dumpvale stuck open, or a split pipe...etc.
inparticular, the one from the wastegate to the boost solenoid.
coyoteboy
posted on 24/2/11 at 11:12 AM Reply With Quote
My guess would be on a vac leak if it's not speed-density based fueling, I'm not sure on that car. The main problem with those cars are melted pistons, horrific piston slap and auto box failures IIRC
meany
posted on 24/2/11 at 07:22 PM Reply With Quote
i wondered when that was gonna come up
sebastiaan
posted on 24/2/11 at 08:47 PM Reply With Quote
Could be anything, and you don't have a hope in hell of doing a quick compression test as its a boxer engine. Unless it is cheap as chips, i'd walk away although they are really capable cars.
posted on 24/2/11 at 10:42 PM Reply With Quote
I bought my Fiat Coupe 20VT with a misfire at idle, the seller thought it was a coil pack. Fortunately I bought it very cheap and assumed the worst, so I wasn't too disappointed to find the ring lands completely broken up on one of the pistons.
A compression test would let you know one way or the other.
[Edited on 24/2/11 by MikeRJ]
