Author: Subject: r1 speedo
shorts
posted on 28/2/11 at 06:05 PM Reply With Quote
r1 speedo
hi all
my mk has a 2008 r1 motor, how do i get the speedo to operate ie can i use the yamaha speed sensor and does it work on magnetic pulse ????????????
regards
dave
CRAIGR
Contributor
Posts 2755
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 28/2/11 at 06:18 PM Reply With Quote
Are you using the yamaha clocks ?? If so a speedohealer should do the job just fine.
http://www.healtech-electronics.com/
[Edited on 28/2/11 by CRAIGR]
shorts
posted on 28/2/11 at 06:25 PM Reply With Quote
r1 speedo
hi craig
yes i am but its the sensor and pick up i need to know about. speedo healer is to put on once i have a reading i think.
CRAIGR
Contributor
Posts 2755
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 28/2/11 at 06:30 PM Reply With Quote
Speedohealer on my 2003 r1 just plugged into the loom uses the yamaha sensor and is alterable to suit your diff and wheel circumference.
shorts
posted on 28/2/11 at 06:35 PM Reply With Quote
r1 speedo
what did you use for the pick up do i need to use magnets?
CRAIGR
Contributor
Posts 2755
Registered 30/8/05
Location Sussex
Member Is Offline
Photo Archive Go!
posted on 28/2/11 at 06:38 PM Reply With Quote
Pick up is in the bike gearbox on the 2003 and the healer uses that ,no need for magnets etc. Pretty much just plug and play really.
adithorp
posted on 28/2/11 at 07:43 PM Reply With Quote
As above the speed sensor is built into the gearbox. No need for anything else but connecting the Yamaha clocks to the loom.
http://jpsc.org.uk/forum/
Davey D
posted on 28/2/11 at 08:42 PM Reply With Quote
the standard pickup is in the gearbox, so just hook up the clocks to the loom, and it will give you a readout.. albeit wrong due to the different ratio from the diff, and wheel size. just get a speedo healer plugged in line, and adjust it to read correct
shorts
posted on 28/2/11 at 08:49 PM Reply With Quote
Originally posted by shorts
hi all
regards
dave
thanks to you all for the advice it makes sence now.
Marky911
posted on 9/3/11 at 09:00 PM Reply With Quote
Hi lads,
sorry for the thread hijack OP..
My Global GT light (2005 R1 engine) uses most of the R1 loom and R1 clocks however the speedo is completely blank and the engine management light is on.
Not bothered about light but, would be good to get speedo working so I can see what sort of speed I'm actually doing.
Any ideas? Is there a wire I can check is actually where it should be, etc?
Thanks. Mark.
