Author: Subject: Engine in at last!!!!
Eternal
posted on 18/3/11 at 09:04 PM Reply With Quote
Still need to mill down the 26 into a 25 on the pully cover.... Also need to install cross bars below the engine mount but will do that when i next remove the engine. Real glad i did the chassis stretch!
Monday it will have its wheels! But still looks nice imo!
[Edited on 18/3/11 by Eternal]
Xtreme Kermit
posted on 18/3/11 at 09:10 PM Reply With Quote
OMG you were serious about it!
Menthol
jacko
posted on 18/3/11 at 09:26 PM Reply With Quote
At last some one with a proper engine great work
where do you live near Hull i hope i would love to see it in the flesh
Jacko
daniel mason
posted on 18/3/11 at 09:28 PM Reply With Quote
wowsers!!!!
PSpirine
posted on 18/3/11 at 10:05 PM Reply With Quote
How much did you stretch it by? Do you have dimensions/plans? I'm very interested in this!
Looks awesome
Pavs
Mr Whippy
posted on 18/3/11 at 10:51 PM Reply With Quote
omg thats a big engine
coyoteboy
posted on 18/3/11 at 11:24 PM Reply With Quote
Wowsers that's a big, tall heavy engine for such a dinky chassis! Should go some!
myke pocock
posted on 18/3/11 at 11:31 PM Reply With Quote
What you doin' with that mahooosive lump in there???? Stick with a whooozy old 1300 x flow like me. Quite enough to frighten you for a start then think big!!!!!!
Eternal
posted on 19/3/11 at 04:25 PM Reply With Quote
hummmmm going to need allot more braces compared to the standard book stuff. This is the idea i have come up with. Originaly i was going to remove the current engine bay cross brace then install a new type that went up to the firewall brace then down to the engine mount, then back upto the top of the wishbone mount. But i might as well leave it in to add a little extra support. All this bracing will be done in 19mm box
What do you guys think about it?
Stuart_B
posted on 19/3/11 at 06:09 PM Reply With Quote
that is going to mental
Eternal
posted on 19/3/11 at 07:50 PM Reply With Quote
Will this is what i have done so far. Bit overkill but hay! Only downside that i have noticed is the top and bottom rail has pulled towards each other by a total of 1mm in the center on both sides. Guess its where the cross braces have cooled and pulled down a little. you guys think this will be a problem? Or should i put a jack in there attempt to bend it back?
