Kev99
| posted on 19/3/11 at 08:01 PM |
Cam Cover Mod 08 R1
Are the modifications u need to do on the 2008 the same as the 04 /06 r1 Cam cover ?
As the read valves look a little different do I remove both the read valve and the curved plate? To leave just the the plate that holds them
  breather
Also what size hole have u used to drill in in the cam cover and do u replace the steel baskets afterwards?
Pos 1 Block hole up
Pos 2 Drill breather hole
  Cam cover
Is this all that's required to be done?
Kev..............
[Edited on 19-3-11 by Kev99]
adithorp
| posted on 19/3/11 at 08:48 PM |
Those look the same as my 06 ones. I removed both bits. blocked the holes at 1 (I used tapper pins, others have used grub screws) and drilled
5/16" holes at 2. I refitted the basket bits and put folded, fine ally mesh between them and the covers to condense oil vapour on so it drains
back in.
http://jpsc.org.uk/forum/
Kev99
| posted on 19/3/11 at 08:55 PM |
Thanks for the reply thats what i will do then
Just looked differant from the pics ive seen on here
Kev.......
