Nitrogeno25
| posted on 26/3/11 at 04:43 PM |
Duratec height
Can anybody with a 2.0 Duratec engine measure for me the height from the lip of block to the lip of the cylinder head?
What I'm trying to determine is the total height if I get a raceline shortened wet sump and a shortened cam cover.
Height of the eom sump and height of the cam cover would be helpful to!
Thank you very much.
flak monkey
| posted on 26/3/11 at 07:51 PM |
I cant give you an exact dimension, but the overall engine height with a shortened sump (which are 75mm deep) and a standard rocker cover is about
1/2" about higher than a pinto. So its a tall engine.
The cam cover will save you about 10mm or so over the std one. I managed to squeeze mine in to have about 5mm clearance to the bonnet and end up with
more ground clearance than with the pinto.
Sera
http://www.motosera.com
Nitrogeno25
| posted on 26/3/11 at 08:01 PM |
Thank you very much!
I read the low profile cam cover can really save 25mm (30mm according to raceline).
If you can give me the dimension I would be very grateful
Thanks again!
