Author: Subject: A little light over 50mph!!
Krismc
posted on 26/3/11 at 05:20 PM Reply With Quote
the front is a little light over 50mph, is this normal?
Ive got a sierra steering wheel fitted and its a bit big, so maybe its because im not used too it and im over correcting so im getting a new smaller wheel fitted soon. Any other tips?
daviep
posted on 26/3/11 at 05:39 PM Reply With Quote
Is your tracking setup properly? Mine was proper scary the first few times I used it before I set the tracking.
Regards
Davie
hicost
posted on 26/3/11 at 05:50 PM Reply With Quote
Castor
Sounds like the castor angle could be out (not enough)
Whats it like at 80 / 100mph or coming off the throttle from a higher speed?
James
"I cant do that without accidentally grabbing hold of the work of the divine potter"
posted on 26/3/11 at 05:53 PM Reply With Quote
Ideally you want a small amount of toe-in on the front ---- important thing is to avoid toe-out.
posted on 26/3/11 at 05:56 PM Reply With Quote
And check the rear has toe-in --- rear needs a bit more toe-in than the front.
Krismc
posted on 27/3/11 at 09:17 AM Reply With Quote
James
I havent had it up that far, have only took it on the local 50MPh duel carridge way (it may have went 51 ) but coming of throttle at 50ish is a bit skitish, Just feels very very light and a few wavy corrections too hold on when allowing it to slow, and then pulls a little too left under braking, but that could be new brakes etc or a bit of bleeding required.
Cant take it back out until i get the alternator sorted.
Krismc
posted on 27/3/11 at 09:19 AM Reply With Quote
Any Vortx owners got the exact settings ? and anyone locally who has a guage.
Sounds just like my car when I had the front toe-in set to 0 degrees. Sensible toe-in fixed it.
omega 24 v6
posted on 27/3/11 at 09:59 AM Reply With Quote
Get some front toe in. Mines had toe out first run and it was mega skittish especially under braking and 2 up. Almost had a mind of it's own. Now it's fine.
Krismc
posted on 27/3/11 at 06:28 PM Reply With Quote
How much is a little?? ive never even set it up before, mnr set it up for IVA, then readjusted too a nominal setting.
They did reccomend i have it set up after even thing beds in, as every single thing is new.
Anyone got a rough guide, and advise on how to roughly check it all on garage floor?
[Edited on 28/3/11 by Krismc]
Krismc
posted on 28/3/11 at 02:37 PM Reply With Quote
I have the correct settings from the manufacture, and confirmed it was setup before leaving the factory and will check 2moro, and then again in a 100miles or so once everything has loosened up a bit.
It may just be me used too a 2 Ton Audi with 150Bhp, then driving a 500Kg car with the same.
Thanks for everyones help
posted on 28/3/11 at 03:06 PM Reply With Quote
All cars of the general Locost/Westfield general type have noticeable amounts of bump steer because of this ride height variations due to springs settling can have a significant effect on toe-in.
Try 1.5mm +/- 1 mm toe-in on front measured at the wheel rim (approx 3mm at tyre tread.)
on rear try 2mm +/1mm toe-in
If the car has had an initial set-up then i would just check toe accross the axles using a Trakrite ---
see http://www.locostbuilders.co.uk/viewthread.php?tid=152593
posted on 28/3/11 at 03:41 PM Reply With Quote
Don't forget to set your ride heights to MNRs recommendations (as mentioned in the other thread).
This also makes a BIG difference if set wrong.
posted on 28/3/11 at 04:07 PM Reply With Quote
Yup, that's what I was just going to mention. Having the rear of the car a little higher than the front helps here. Unfortunately I have to have the front a lot higher than the rear due to the sump. So at speed my car is very fun
Krismc
posted on 28/3/11 at 06:34 PM Reply With Quote
Yea rear is 25mm higher than front.
Gergely
posted on 4/4/11 at 09:04 AM Reply With Quote
Hi, when I asked Marc about the tracking and setup this is what he told me:
setup 1mm toe in all round
camber 0.75 degrees / 1 degree all round
tyres 16 psi front 18psi rear
It is slightly different in the manual, but he says my car is newer than the ones in the manual.
(RT inboard, R1 engine, 13" wheels)
I hope this helps.
Gergely
Our build pictures
