richardhuggins
posted on 11/7/04 at 08:20 PM |
Headlights & Dip
Hope someone can help!
My MK has a vicki green wiring loom, but I can't get the dip & main beam to work, but it will flash, I've changed the colum switches
over 3 times and have wired exactly to diagram (everything else is fine)
ady8077
posted on 11/7/04 at 08:26 PM |
Hi
I assume Sierra switches? if so have you earthed the fixing bolt ? One of the mounting lugs has a brass ring on it
Adrian
posted on 11/7/04 at 08:30 PM |
as adrian says, the 'flash' earths thru a different circuit to the perminant full beam. the perminant full beam's earth is switched
by the light switch, so that on the right stalk you select sides and dips, and the left stalk only selects between dip and main when the lights are
already on, but the full beam can be flashed at any time. have a look at the haynes diagram of the light switch, specifically the internals at the
beginning of the appropriate section, and ignore the various dim/dip relays etc.
posted on 11/7/04 at 10:07 PM |
It's usually the brown and black wire that joins the two switches together that causes problems. Anything with brown on it is an earth in Ford
wiring terms.
