liam.mccaffrey
posted on 11/7/04 at 10:28 PM |
wheelbase
i am building a custom middy with fwd donor, what i want to know is whether to keep with the donors wheelbase and track or is it not that important.
for info
wheelbase is 2580 mm
track is 1453mm (measured from tyre centres)
Build Blog
Build Photo Album
TheGecko
posted on 11/7/04 at 11:10 PM |
Liam,
I'm building with Corolla running gear. I don't even know what the donor wheelbase is (I could look it up I suppose). I've set my
wheelbase at about 2350mm as a matter of packaging and proportion as much as anything. I've got scope to change the wheelbase by +/- 50mm or so
by making different front wishbones.
The track is pretty much set by the running gear unless you want to start making custom axles (expensive!). The Corolla is 1440mm - I'll have
about 1480 because the wheels I'm using are 20mm offset to suit the front suspension rather than the ~40mm FWD offset the Corolla would normally
have. The offset change isn't a problem (hopefully!) because the rear wheels aren't steering.
Dominic
kb58
posted on 12/7/04 at 02:12 AM |
It's not important. In fact, don't even look at it, wheelbase that is. Just design your car and whatever it ends up being is
"correct."
Track on the other hand does matter, but only to the extent that if you make it different then stock, you need custom axle half-shafts made, about
$300-$400. Also, I learned the hard way what happens if you make the track a lot less then stock; the CV angularity increases very quickly! That is,
making the axles, say, 30% shorter, doesn't mean CV angularity increases by 30%... it's a lot more. It's something that should be
modeled.
[Edited on 12/7/04 by kb58]
pbura
posted on 12/7/04 at 02:58 AM |
Those are nice dimensions for a sports car, about the same as Graber's, I think.
Pete
crbrlfrost
posted on 12/7/04 at 05:02 AM |
Not to be argumentative, but I wouldn't go as far as saying that wheelbase is unimportant. It isn't critical and offers a wide range of
options, but does have an effect on pitching moments and thus load transfer. Again, not a huge deal as long as it will almost inevitably fall within
the "norm," but something to keep in mind just because. Cheers!
tadltd
posted on 12/7/04 at 09:09 AM |
A good guide for a sportscar is to use a wheelbase to track ratio of around 1.6 (as found on most high-end racing cars).
I would agree that you should keep the stock track-width to save yourself a lot of problems and unnecessary expense.
Best Regards,
Steve.
www.turnerautosport.com
kb58
posted on 12/7/04 at 02:22 PM |
I agree, but it tends to work itself out in design. By the time he puts the seat, engine, and wheels where he wants, well, there it is. I guess
I'm making the leap of faith that he isn't picking a wheelbase of 37"... or 217"!
sgraber
posted on 12/7/04 at 03:20 PM |
It's close. My wheelbase is 2490mm and track is 1448mm (measured to hub faces) for a ratio of 1.7, which is a little longer than the ideal.
Your donor puts the ratio at 1.78 so you could stand to shorted your wheelbase a bit. But like was mentioned above, packaging of all the parts in
between the wheels will be a largely determining factor for the wheelbase. Simplicity and cost indicate that maintaining track is wise.
Graber
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
Alan B
posted on 12/7/04 at 04:37 PM |
I'm pretty certain I have the same track as Steve (we are both far too frugal to go for custom axles...LOL)
My wheelbase is 2337mm (92 inches)...a little less, but similar...
[Edited on 12/7/04 by Alan B]
liam.mccaffrey
posted on 12/7/04 at 06:16 PM |
i was going to stick to standard locost fron suspension geometry because i have cortina uprights, butwhat is the track of a bookcar? compared to the
(tyre centre to tyre centre) track of the nubira at 1453mm
Build Blog
Build Photo Album
robinbastd
posted on 12/7/04 at 09:38 PM |
"My wheelbase is 2337mm (92 inches)...a little less, but similar..."
Mines marked out at 2337.5mm,so it's a little bit longer than Alans
http://smuttygifts.com/
cymtriks
posted on 13/7/04 at 10:25 PM |
chassis design for middys
Liam,
Regarding your request for a chassis design my thoughts on a middy chassis for transverse engines is now in the photos section. The thoughts are
preliminary but I have done a quick FEA analysis and the stiffness is good. The details need to be filled in to suit a specific build. I know this is
a bit off thread but I hope it helps.
Constructive comments welcome on the middy chassis btw.
liam.mccaffrey
posted on 14/7/04 at 06:32 PM |
cymtricks,
this is fantastic its exactly what i wanted,
after deciding to do a middy i began to design my own chassis and what i came up with is very similar.
the only differences being that i included a simple transmission tunnel for routing cables and hoses,
also i wanted to use my original locost nosecone so i designed the front with suitable dimensions in mind. With your help i now have a good idea
about what tube sizes and bracing to use
after looking at the model i was wondering about the "2x1 dashboard frame side" you mentioned on the drawing. i am not sure i understand
what you mean. is the hand drawn view the junction at the front of the sills?
i don't understand where the shaded part, the 2x1, is going to or from
please forgive me if i am being dumb its been a long day!
[Edited on 15/7/04 by liam.mccaffrey]
Build Blog
Build Photo Album
cymtriks
posted on 21/7/04 at 09:56 PM |
Liam,
The design is unfinished. By which I mean that details specific to a build need to be worked out.
The 2x1 tube runs vertically up the side of the scuttle/dashboard frame and closes the end of the sill. The view shows the sill meeting it from the
left and the dash top joining it from the top of the hand drawn view. It is shown shaded to highlight it in the picture.
The 4x2 tube down the side of the seat is end on.
The sill has ready made ends of the right width. the small face of a 4x2 at the back and the wide face of a 2x1 at the front.
The footwells will probably need tubes running from the ends of the 2x1 tubes to the front suspension region to stiffen up the panels. Triangulation
may not be necessary if the panels are all welded in place.
If you scroll back through my posts I have put a middy seven design on this forum. It has a very similar engine bay structure to my above post with
the rest being locost book inspired.
[Edited on 21/7/04 by cymtriks]
liam.mccaffrey
posted on 22/7/04 at 09:09 AM |
hi cymtriks
i have seen your drawing, without realising you were its source, i have drawn a cad version of this drawing which you are welcome to, when i saw it i
thought it was so cool, it just looks really balanced,
i am about to scale my drawing up, as at the moment it is a scale cad drawing(i know this is wrong but i did a vector convert of the jpeg)
at the moment i it looks as though i'll build the engine bay as per you model with a locosty front. am doing chassis next week so i can post
some pics and info if you are interested!
liam
[Edited on 22/7/04 by liam.mccaffrey]
Build Blog
Build Photo Album
posted on 22/7/04 at 07:38 PM |
hi liam, just a few comments since ive been thinking middy myself at times!
firstly, i would drop the transmission tunnel, as there is no need for strength here. Any brake pipes and wiring i would just make a minimal
fibreglass cover for. I would use foam instead of seats, glued directly to the floor, to keep weight both minimal and low. you can afford to be low
cos theres no engine to see over. ditto book front suspension dimensions, it makes life much easier. without a transmisson tunnel and with basic seats
you can have a narrow cockpit, leaving more room for reinforcement (if thats your priority) or intakes for the radiator/engine.
if i think of any more, i'll add it later!
Cita
posted on 22/7/04 at 07:49 PM |
I'm not sure if the tunnel doesnt add strenght in terms of twist,could be wrong though
liam.mccaffrey
posted on 22/7/04 at 10:11 PM |
when i saidtransmision tunnel i meant minimal, as per you suggestion of fibreglass cover, also i am making a seat out of foam as you suggest i am a
big guy i need all the room i can get.
this is really good ie lots of feedback and thoughts from others, it feels like the plan is really coming together, coupled with the fact that i have
collected virually all of the required components all that is left now is a lot of blood sweat and tears!
thanks
Build Blog
Build Photo Album
posted on 23/7/04 at 07:30 AM |
well it does add a little to strength, but seeing as its just about down the axis of twist, any force at the wheels has more leverage over the
transmission tunnel that it would have over tubes at the side of the car.
kb58
posted on 23/7/04 at 04:42 PM |
That's one reason why I build an enclosed car, since a roll cage structure is much more resistant to twist since the tubes are so far apart.
liam.mccaffrey
posted on 23/7/04 at 05:46 PM |
today i printed out a full size cad side elevation of the car to put on my garage wall. its the seven based middy cymtriks designed, will
post photo soon
i think this will help me design the chassis as it has given me some overall dimension as well as wheelbase
which is 2323 by the way
Build Blog
Build Photo Album
