Author: Subject: FS: FZR1000 Engine, Carbs, Clocks, CDI, Loom etc
SeaBass
posted on 10/4/11 at 06:30 PM Reply With Quote
Yamaha FZR1000 145Bhp engine complete with most bits to get it running, loom, ignition units, leads, clocks, starter, alternator, starter solenoid, sprocket cover (currently removed), clutch slave etc + Haynes Manual
Purchased from Mango a while back for a buggy project but no time to start - cleaned it up it's been sat doing nothing. Looks tidy and no signs of damage - still clean oil in the sump. One bad point: I removed the plugs but one has snapped off leaving the thread in the head - a classic issue. I got fed up at this point and left it - should be fairly easy to remove with patience.
Got to go so £100 for someone to collect it / can drop off in Edinburgh.
James
[Edited on 10/4/11 by SeaBass]
KAMBO
posted on 10/4/11 at 08:49 PM Reply With Quote
any idea what year the engine is ?
SeaBass
posted on 11/4/11 at 08:08 AM Reply With Quote
I'll try and work it out from the engine number. It's defo after 89. They were only made until 95 if that helps?
James
KAMBO
posted on 11/4/11 at 09:33 AM Reply With Quote
u2u sent
tyrrell
posted on 11/4/11 at 09:35 AM Reply With Quote
i will take it,
what about if i was to arrange a pick up from pallet force or something/
contact me on 07850386994
