Author: Subject: Rusty nuts - ooh er
pdm
posted on 16/4/11 at 08:21 AM Reply With Quote
Rusty nuts - ooh er
Hi
I've been trying to get some nuts and bolts clear of rust - I've tried malt vinegar, white vinegar, coke but no joy.
Don't really want to wire brush as I dont want to damage threads - they are small headlight bolts.
Noticed in CKC that Ash used Hammerite Rust Remover
Anyone else used this and what were the results like ?
Also the adjuster screws go into plastic grommets - the plastic is stained with some rust. Anything except elbow grease I can use on the plastics without damaging them ?
thanks
Paul
designer
posted on 16/4/11 at 09:02 AM Reply With Quote
Electrolysis to remove rust.
http://www.shedworks.eu/projects.html
ReMan
posted on 16/4/11 at 09:03 AM Reply With Quote
Wire brush shouldnt dfamage them
Can you not replace with stainless cheap enough if small or are they specials?
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
cliftyhanger
posted on 16/4/11 at 09:07 AM Reply With Quote
Acids won't damage plastic.
For cleaning up rusty nuts/bolts etc (I do a LOT of that with the old cars) I use a wire brush in a bench grinder. Before that, a wire brush in a drill, clamped in a workmate. MUCH easier and safer than holding the drill and object being cleaned.
pdm
posted on 16/4/11 at 09:12 AM Reply With Quote
Reman - I'd only assumed they were specials. They are headlight adjustment screws that screw into a grommet. They have a collar near the screw head which fits into a slot around the headlamp bowls (these are 7'' MX5 headlights). They were quite expensive when I asked at dealers. I wanted to try and clean them as there's nothing wrong with the threads they are just a bit rusted.
Sounds like wire brushing is way to go then with screws/bolts and acid on plastic.
So next question - where might I buy acid ??
ETA - thanks for the advice as well !!
[Edited on 16/4/11 by pdm]
cliftyhanger
posted on 16/4/11 at 09:15 AM Reply With Quote
Vinegar, citric acid (heard good things about citric acid for cleaning rusty metal, but should work well with plastic. Downside is the seller will assume you are a drug dealer )or phoshoric acid, sold as rust remover. Guess "wonder wheels" would work too as it contains hydrochloric acid IIRC.
ashg
posted on 16/4/11 at 10:00 AM Reply With Quote
the hammerite stuff was ok but i still had to finish them off with the wire brush to get the shine back. a wire brush wont damage the threads
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
pdm
posted on 16/4/11 at 11:08 AM Reply With Quote
great thanks everyone - I'll try some wonder wheels as got some in the garage.
Reckon I'll use what I've got to soak them and then get busy with the wire brush
thanks again
