Author: Subject: speedo blank
Arthur T wareing
posted on 21/4/11 at 02:43 PM Reply With Quote
speedo blank
Hi all I have removed speedo cable and need to fit a blank in my type 9 where do I get one and does it fit the same as speedo cable as I have always used speedo supplied with kit before
Mr Whippy
posted on 21/4/11 at 02:49 PM Reply With Quote
tbh I just wouldn't bother, there's an oil seal to keep the dirt out and it will be quite happy with no cover. The speedo drive shaft is made of plastic so no rust problems
[Edited on 21/4/11 by Mr Whippy]
Bluemoon
posted on 21/4/11 at 03:09 PM Reply With Quote
You could just chop the end off the cable, then put the end back.. Job done.
Dan
big_wasa
posted on 21/4/11 at 03:48 PM Reply With Quote
I just left it open on my mt75. No leakage.
Humbug
posted on 21/4/11 at 05:31 PM Reply With Quote
I found a handy-sized rubber stopper thing which fitted over the hole
