New Topic New Reply
Author: Subject: Chassis design help
lukeep
posted on 26/4/11 at 03:53 PM Reply With Quote
Chassis design help
hello guys i posted on here a while ago. I am looking to see if someone preferabally local would be willing to mentor and help me and my mechcanic friend design and build a chassis i understand box section or tubing as the chassis i need help mainly with suspention as double A frame style
1) how do design a double A frame front and rear suspention
2) Designing a light weight sturdy mid engine kv6 chassis
I know i am a novice but i really want to learn any help will be a bonus.
posted on 26/4/11 at 03:58 PM Reply With Quote
Are you working on paper or in CAD?
Either way, you could post up your design ideas on here and receive the benefit of a much wider audience.
Might also be worth searching out some books on chassis and suspension design. Staniforth, Des Hammill, Haynes etc al cover aspects of deisgn and build.
Kwik
posted on 26/4/11 at 08:09 PM Reply With Quote
what will be the chassis use?
will it be a racer single seater, locost 7 type car, etc.
all the info, drawing, ideas, sketches on napkins, will all help
lukeep
posted on 27/4/11 at 10:25 AM Reply With Quote
Hi guys I have added some quick mock ups of the main chassis using the abomination that is sketch up positive criticism gratefully accepted
Miks15
posted on 27/4/11 at 10:38 AM Reply With Quote
mock up of entice chassis
mock up of en-tice chassis top
i think you need a bar across the big opening on the side view. Theres little to no strength in that area and as thats where you be sat i doubt youll want it buckling around you!
designer
posted on 27/4/11 at 10:45 AM Reply With Quote
Agree, it's going to bend.
Either needs some sills or a larger tunnel down the middle.
lukeep
posted on 27/4/11 at 05:40 PM Reply With Quote
Cheers guys on the side view i cant re enforce there with a bar as the canopy like on the sterling nova will be there with a intergrated roll bar in the canopy so what are my choices?
kb58
posted on 28/4/11 at 02:41 AM Reply With Quote
Oh dear, yeah that'll bend in torsion really easily. The secret is to picture a tube; twisting a tube is really difficult, and you need to replicate that somewhat. The easiest way is either a big central tunnel that's fully boxed in, outboard boxes below the doorways, or both.
And its book - http://www.lulu.com/shop/kurt-bilinski/kimini-how-to-design-and-build-a-mid-engine-sports-car-from-scratch/paperback/product-4858803.html
Miks15
posted on 28/4/11 at 07:47 AM Reply With Quote
So are you building this based on some other car? If so it would help if you posted a pic of the body you are trying to fit it to. Then well have a better idea of your finished goal
lukeep
posted on 28/4/11 at 07:28 PM Reply With Quote
its not baced on any other car i am just borrowing the concept that the car will have no doors the whole canopy will rise up and you will get out im currentally mocking up some new models
Paul_C
posted on 28/4/11 at 08:58 PM Reply With Quote
That's some impressive sketchup work.
If you want to calculate lateral, beam or torsional stiffness then I recommend LISA Finite Element Technologies at http://www.lisa-fet.com/
It's free for 1300 nodes which should be plenty for a spaceframe.
I used it on the spaceframe shown in Appendix 1 of Racing and Sports Car Chassis Design by Michael Costin and David Phipps.
The torsional stiffness came out as 1350 lbf ft required for 1° of twist.
All that is required is the x, y and z node co ordinates, the cross section of the members and the material Youngs modulus.
Miks15
posted on 28/4/11 at 09:04 PM Reply With Quote
If you are copying the sterling concept then i reckon you can still have a higher beam across
Is this the one you mean?
I reckon a beam the same height as youre other rails and then have that as your top sill with the canopy sat on top should work
Badger_McLetcher
posted on 29/4/11 at 03:51 PM Reply With Quote
If you can't put in sidebars then increase the size of the drive tunnel and make sure it's fully pannelled/triangulated. May not harbour your drivetrain but you can still put stuff in there.
If disfunction is a function, then I must be some kind of genius.
blakep82
posted on 29/4/11 at 04:03 PM Reply With Quote
its hard to draw it in on the drawing you've posted, but it looks real easy to add a bigger tunnel in.
really needs to be taller and a bit wider than you've got i think, but what you've got looks easily changed to suit
think beefing up the sides will be a lot harder
look at TVR chassis.
________________________
Mark Allanson
posted on 29/4/11 at 04:17 PM Reply With Quote
The Stirling was a copy of Richard Oakes Nova
tug
posted on 29/4/11 at 04:24 PM Reply With Quote
Aren't those triangles a bit big? Remind me of buggies.
I don't want to be a dick, but from the pics you have provided it let me think that the car do NOT have the same wheel-to-wheel distance. And they don't seem to be the same height.
Interesting design hope it works
coyoteboy
posted on 29/4/11 at 06:15 PM Reply With Quote
Also zero triangulation in the rear box section. To be honest i'd be starting from scratch on that as there appears to be few redeeming features - looks like it could be lighter, simpler and stiffer. Check out some race car chassis design books and on top of that decide how comfy you'd be in it in an accident.
Kwik
posted on 29/4/11 at 06:33 PM Reply With Quote
that design is good, but you need something connecting the front and rear like mentioned above.
the triangulation at the rear looks fine as long as it is a light weight car, look at the 7 chassis, loads of squares in them, you dont need to triangulate everything and you dont need to "bird cage" everything (having lots of tiny triangles.
also you can used stressed skin instead of triangulation in parts so dont jump the gun and tell him he needs more triangulation... but you defiantly need a transmission tunnel or something along the sides.
Liam
posted on 29/4/11 at 09:15 PM Reply With Quote
Good starting point but that central section needs addressing seriously or it'll fold in half when you get in!
I appreciate it's just a mock up and not necessarily dimensionally accurate, but the proportions look rather odd - you've got pretty much a square footprint! It's either abnormally wide or the cabin is abnormally short.
You need at least a full and triangulated transmission tunnel, and ideally also sides/sills of a decent height. You should be able to get at least 8" I would have thought and still be easily able to step in. Also, have some width in the side sills too, not just a single tube thickness - build them like a box either side of the car.
Finally - rising canopy inspired by the Nova/Stirling? A bit... 80s sci-fi if you ask me!
Good luck
lukeep
posted on 1/5/11 at 05:23 PM Reply With Quote
Hello guys I had some time this weekend so I took you’re advice onboard I have addressed the lack of triangulation and re enforcement well lack of as well. again criticism gratefully accepted
Also En Tice Will look nothing like the sterling nova in any way shape or form.
REVISION FRONT
REVISION FRONT
REVISION SIDE 2
REVISION SIDE 2
REVISION SIDE 1
REVISION SIDE 1
REVISION TOP
REVISION TOP
designer
posted on 1/5/11 at 06:53 PM Reply With Quote
One of the cockpit side rails, from the shoulder area, meets another half way, without any support, which will introduce a bending motion.
Kwik
posted on 1/5/11 at 07:16 PM Reply With Quote
and you wanna make a jig for that? so many odd angles...
your going to have a fiberglass body right? and im guessing interior paneling to cover the majority of the tubes. so why not keep it simple?
your design looks awesome, but in reality making a jig, cutting everything to the right angles and welding it neatly will be difficult, my advice would be to keep it simple, especially if it is going to be covered up anyway...
New Topic New Reply
