Author: Subject: ZZR1100 Engine package
m8kwr
posted on 3/5/11 at 06:14 PM Reply With Quote
Its from a 1990 year Bike, apparently had 20,000 miles on the clock.
Its a complete engine/ gearbox with
Wiring loom with Switch Gear
Clocks
Carbs
Airbox
Radiator and Expansion Tank
Oil Cooler and pipework
Standard exhaust
Race exhaust
Ignition system
Chain.
New Sprocket
Haynes Manual.
Copy of original registration certificate with engine no, etc on it.
Also have a GPZ900 sump and oil pickup pipe to help raise the sump so the engine can be fitted lower in a vehicle.
As far as I an tell I believe this has had the carb tops changed to remove the power restriction that it originaly had when first sold in the UK.
Its pretty much a complete package. I was going to use it to run off a chain diff (which might be for sale as well!!!!)
Looking for about £300. I live 2 miles from J13 M6 (Stafford)
m8kwr
posted on 5/5/11 at 06:58 AM Reply With Quote
now dropped to £250
ReMan
posted on 5/5/11 at 08:05 AM Reply With Quote
u2u'd
www.plusnine.co.uk
∙،°. ˘Ô≈ôﺣ
