Author: Subject: Buying a Duratec bellhousing
neilp1
posted on 7/5/11 at 08:19 PM Reply With Quote
Well It's nearley time to dig deep and part with some hard earned cash on a Duratec to type 9 bellhousing. Now I've seen the one on Rally design website and find this the cheapest by quite a way. BUT has anyone on here used it if so, is it any good? If no one has used it which ones have you used and how easy to set up (hydraulic).
Cheers in advance,
Neil
flak monkey
posted on 7/5/11 at 08:23 PM Reply With Quote
Its the Titan one, and its fine. There are only a couple of people actually cast them anyway.
Sera
http://www.motosera.com
big-vee-twin
posted on 7/5/11 at 08:28 PM Reply With Quote
Here's the Titan Bell Housing with Titan Slave cylinder and Thrust Bearing.
To fit the Hydraulic cylinder you have to cut off the guide tube from the front of the type 9 to fit it and then measure up for a spacer to make sure the bearing pushes on the fingers of the clutch.
Takes a bit of time bit is straightforward.
[img] Duratec clutch cylinder
[/img]
http://www.triangleltd.com
redeye
posted on 10/5/11 at 09:20 AM Reply With Quote
Neil
Theres a bellhousing on Ebay at the moment.
It looks like the raceline bellhousing from the pictures, which I believe is the same one Flak used in his build.
DURATEC BELL HOUSING | eBay UK
worth a look.
cheers
Patrick
