richwill
posted on 10/5/11 at 07:29 PM |
uneven pinto idle
My standard injection pinto wont idle steadily. It keeps hunting up and down the revs. What could be causing this?
I have been told it may be the idle control valve which has a problem and will be removing it and giving it a clean but should i check anything else.
flak monkey
posted on 10/5/11 at 07:30 PM |
ICV or an air leak.
Sera
http://www.motosera.com
mcerd1
posted on 10/5/11 at 07:47 PM |
I should have a spare ICV or two
they've been off the car for a few years now nut they might be woth a shot if you can't find any air leaks
[Edited on 10/5/2011 by mcerd1]
adithorp
posted on 10/5/11 at 08:02 PM |
Clean the idle controle valve and the throttle butterfly with carb cleaner. If that doesn't help check for inlet air leaks.
http://jpsc.org.uk/forum/
