Author: Subject: Compressor output
skodaman
posted on 24/5/11 at 09:56 PM Reply With Quote
Compressor output
Do any of you mathematical genius' (genii?) know the formula to convert litres/min to cfm. and any comment on if 1350l/m is any good for spraying cellulose/ blast-cabinet, airtools etc?
Skodaman
mcerd1
posted on 24/5/11 at 10:13 PM Reply With Quote
by the power of google 1350 l/min = 56.1 cfm (its too late for anything else tonight, my brain gone...)
btw this is what google came up with: linky
[Edited on 24/5/2011 by mcerd1]
skodaman
posted on 24/5/11 at 10:20 PM Reply With Quote
'(its too late for anything else tonight, my brain gone...)'
Mine too welding and simultaneously setting fire to mdf makes for a headache.
Skodaman
mcerd1
posted on 24/5/11 at 10:21 PM Reply With Quote
or this is bit better - 1 liter/minute = 0.035 314 666 213 cubic foot/minute
from this site that I use when I'm stuck: http://www.onlineconversion.com/flow_rate_volume.htm
skodaman
posted on 24/5/11 at 10:27 PM Reply With Quote
Thanks for that. Looks like I'll be blasting everything that doesn't move in the next few days.
Skodaman
SeaBass
posted on 25/5/11 at 06:47 AM Reply With Quote
That's some compressor! I presume a trailer based petrol engined unit? Otherwise you'd be created brownouts in your local area...
JC
skodaman
posted on 25/5/11 at 10:53 PM Reply With Quote
It says on the pump 1360 1/min I thought the 1 was an L for litres. So don't know what this figure means. It's only a 2000watt motor though and single phase.
Skodaman
martyn_16v
posted on 26/5/11 at 07:12 AM Reply With Quote
1360 rpm?
sebastiaan
posted on 26/5/11 at 07:35 AM Reply With Quote
Originally posted by martyn_16v
1360 rpm?
yup...
skodaman
posted on 26/5/11 at 11:23 PM Reply With Quote
Aargh! Why the hell can't they say rpm then? Only !360 rpm. I think I should skim the head and raise the exhaust port to get it up to 9000rpm. After all it does look like a two-stroke.
Skodaman
mcerd1
posted on 27/5/11 at 07:12 AM Reply With Quote
1/m = cycles per min = rpm
