shorts
posted on 25/5/11 at 10:57 AM |
2008 r1 oil light
I HAVE A 2008 R1 MOTOR IN MY MK EVERYTHINGS FINE WITH IT BUT I HAVE THE OIL LIGHT FLASHING. IT HAS THE CORRECT OIL AND AMOUNT, ANY IDEAS ANYONE.
DAVE
Davey D
posted on 25/5/11 at 11:06 AM |
have you been using/running the engine, and it has just happened, or is it a new engine install that your trying to sort out any last niggles?
on the 06 R1 the oil light comes on from a sensor in the sump which is just a float sensor which drops down with low oil level, thus completing the
circuit, and making the light come on.
Have you accidentally unplugged the sensor wiring?(goes round to the underside of the sump) have you fitted a sump baffle, and damaged the sensor?
could something be making the sensor stick in the down(low oil) position?
adithorp
posted on 25/5/11 at 12:40 PM |
Don't know for sure with the 08, but on the 06 it just comes on (doesn't flash) and are a low level light, not presure. They're
tempramental and will come on when... revved with the oil cold or overfilled and run at constant high revs. Could also be the switche has failed or
the wiring is faulty.
http://jpsc.org.uk/forum/
shorts
posted on 25/5/11 at 12:50 PM |
oil light
hi guys
the engine is a new install, i have not put a sump baffle in as its only for road use, but i did add an extra half a litre of oil thinking that was
what should be done. maybe thats it. there appears to no mention of a flashing light in the r1 manual.
Dave
Kev99
posted on 25/5/11 at 04:18 PM |
Hi I've just upgraded my Indy to an 08 R1 this winter and I would not run it without a baffle plate fitted ant the breather mods done even for
the road
Kev...........
PS
Not been out in mine but the oil light dose not come on even when cold or revved
