flak monkey
| posted on 2/6/11 at 02:59 PM |
Camber adjuster inserts
I am about to do a run of camber adjuster inserts. These are steel ones rather than the cheese like aluminium ones various other places sell. They are
directly interchangeable.
21.75mm OD and a 64mm long plain section with a 24mm (or 1" depending on material) hex and M18x1.5 thread.
Basically they fit inside a 25mm x 1.5mm top tube on the wishbone. And will fit the GTS and Rally design wishbones.
£22 per pair delivered in the UK.
[Edited on 3/6/11 by flak monkey]
Sera
http://www.motosera.com
gavin174
| posted on 2/6/11 at 04:16 PM |
yes please if i could have two sets....
could I make a suggestion, that instead off the large nut to adjust
the end is closed with a 17mm or 19mm hex head on it.
would make it so much easier to adjust with socket and ratchet...
there is probably some really good reason why this cant be done
obviously I appreciate it would need a collar instead of the original large hex head to stop it pulling through.
flak monkey
| posted on 2/6/11 at 05:36 PM |
You can get a 24mm or 1" socket on these, I make the hex longer than the aluminium ones to make it a lot easier
Making them with a smaller hex would require welding on a piece of hex bar, and it just costs too much to make them viable to be honest. These are
made from a solid piece of hex bar.
Sera
gavin174
| posted on 3/6/11 at 06:38 AM |
Sounds like a plan.
Could I have 2 sets please
Thanks Gavin.
chrisw_82
| posted on 22/8/12 at 05:50 PM |
Hi there,
Does anyone know if Flak is still making these? Or if anyone has some to sell? I've U2U'd Flak Monkey but no reply
Chris
ReMan
| posted on 22/8/12 at 06:43 PM |
He may not be able to get his mail at the moment due to other commitments
www.plusnine.co.uk
dave r
| posted on 23/8/12 at 05:38 AM |
i hope he has plenty of chips to go with all that salt
I'd love to give my imaginary friend a great big hug,
but this jacket makes it impossible.
wylliezx9r
| posted on 23/8/12 at 09:15 AM |
Theres somebody on ebay doing them, cheap as well.
George Best
sergebelg
| posted on 22/10/12 at 10:14 AM |
Hello
I have searched on ebay but haven't found...
loggyboy
| posted on 22/10/12 at 10:51 AM |
These - but they have ended
http://www.ebay.co.uk/itm/Camber-Adjusters-Steel-Front-Top-wishbone-Kit-Car-Locost-haynes-roadster-super-7-/120997771310
Mistral Motorsport
designer
| posted on 22/10/12 at 10:57 AM |
Those Ebay adjusters are brilliant, contact them, they are a stock item.
sergebelg
| posted on 22/10/12 at 11:34 AM |
thank you
I have sent a request to the seller...
chrisw_82
| posted on 16/4/13 at 05:55 PM |
I've seen them, £12.50, but they're aluminium so just as likely to break as the originals.
I'll try to U2U Flak Monkey again, I didn't hear from him after Bonneville
