Author: Subject: mnr vortx rt+ rear postive camber
andrew_s
posted on 4/6/11 at 03:29 PM Reply With Quote
Hi
should the rears have slight postive camber ?
I have the top camber adjusters fully wound in, and the pro tech shocks spring platform fully down and still seem to have postive camber? is that right. i dont have a camber guage but i would expect a little negative camber.
the only option i can see to get more would be to increase the length of the bottom wishbones on the rose joints
any thoughts welcome, thanks in advance
Andrew
T66
posted on 4/6/11 at 06:05 PM Reply With Quote
is the car dry ?
a driver and passenger will make a difference, tank of gas etc...
lucy
posted on 4/6/11 at 11:01 PM Reply With Quote
Got to be the rose joints then I would have thought.
daniel mason
posted on 5/6/11 at 09:40 AM Reply With Quote
dont think they should be wound in fully mate. get the fronts sorted to correct width and then wind the backs out until they are very similar. around 5mm narrower from hub face to hub face.
