Author: Subject: 08 R1 Power Commander problems
Kev99
posted on 4/6/11 at 06:40 PM Reply With Quote
Hi All
Wondered if anyone can help I've installed an 08 R1(fly by wire version) in the Indy over the winter and running a power commander III USB
The problem I'm getting is that its interrupting the signal to the TPS (throttle position sensor) slightly .
The power commander connects to the wire from the ECU that goes to one of the TPS.
When the engine gets hot and I come of the throttle the engine wont idle when the revs drop its ok when cold, Its ok when I disconnect the power commanded
Got it booked in at Northampton Motorsport on the 16th for a full mapping on the rolling road
I'm asking if anyones had this sort of problem as well if so how did u sort it before getting it on the Rolling Road
Kev..........
eddie99
posted on 4/6/11 at 06:59 PM Reply With Quote
If i was you, id ring dynojet who make the power commander, or ring one of the rolling road companies that are dynojet specialists such as damian at daytuner. If no luck ring Andy Bates, he's installed lots of power commanders and has come across most BEC issues.
http://www.elitemotorsporteng.co.uk/
Twitter: @Elitemotoreng
Facebook: http://www.facebook.com/pages/Elite-Motorsport-Engineering/153409081394323
Kev99
posted on 4/6/11 at 07:13 PM Reply With Quote
Ive had a quick chat to Andy on the phone thats why its going to Northampton Motosport
But was hopeing i could get this little problem sorted before it gets there
Was wondering if the take of point close to the ECU might be the problem and moveing it close to the TPS would help
thats one of the ideas i got but dont want to mess around to much with it so asking if anyones had simler probs
Kev............
afj
posted on 4/6/11 at 07:55 PM Reply With Quote
Kev give mark brewin a call at bsd motorcycle developments at eye on monday morning. There is nothing he dont know about bike engines and power commnders.
Alan
eerrrrrrrrrrrrrrrr
eddbaz
posted on 5/6/11 at 06:02 PM Reply With Quote
As Alan said I would definately give Mark a bell at BSD.
shorts
posted on 6/6/11 at 07:32 AM Reply With Quote
Hi
i AM RUNNING A POWERCOMMANDER V ON MY 08 R1 MOTOR. ITS NOT BEEN SET UP YET ON A ROLLING ROAD BUT I HAVE INSTALLED A MAP FROM THE WEB AND IT REVS GREAT BUT AS YOU SAY IT WILL SOMETIMES STOP WHEN COMMING BACK DOWN TO IDLE. I WOULD BE INTERESTED IN WHAT THE OUT COME IS.
REGARDS
DAVE
Steveczerwionka
posted on 8/9/15 at 08:22 AM Reply With Quote
I am currently having the same problem in my vortx. I got it registered 6 weeks ago and have done 2 k since. I have not been this addicted to so thing since I was 9. But I have to come off the rpm real slow or it cuts out. Having exactly the same problems as you describe. Did you ever get to the bottom of it mate. Please help as it is doing my head in. Cheers steve
jelly head
posted on 9/9/15 at 07:17 AM Reply With Quote
Mine used to cut out when coming off the throttle, was running way too rich around idle, i assume it was dumping in too much fuel when trying to pick up the throttle for tickover. Trimmed a load of fuel out (using a wideband sensor) and it behaved itself then. It was wired in close to the ecu too.
Steveczerwionka
posted on 9/9/15 at 07:43 AM Reply With Quote
Thanks man. Maybe I should get it booked back in to a different power commander installer. I would have hoped that these points would have be accounted for as it was daytuner that first informed me of my problem after it had been mapped on there rolling road after they had installed it. So maybe it could be a small adjustment rwquired with the commander installation.
