Author: Subject: FAST ROAD SET-UP
ALEXARAS
posted on 14/6/11 at 09:30 AM Reply With Quote
FAST ROAD SET-UP
Good morning guys,
After 3 years I think I am close to the end...
So it is set-up time
I am looking for a fast road set-up which will be reasonable on the track as well (including, camber, caster etc) to start with.
My car has the following caracteristics:
RS2000 rear axle (not much I can do there I guess...)
GAZ adjustable shock absorbers
Toyo R888 tyres
185/60/13
205/60/13
What are the common numbers, or the numbers you suggest ?
Furthermore, a few tips on the GAZ adjustability would be of tremendous help.
(Height and stiffness adjustment would be spot on).
Please keep in mind that the car is in Greece, hence shitty asphalt.
Many thanks in advance for your replies !!
Locost 7 RS2000
Beach Buggy Rotary
snapper
posted on 14/6/11 at 10:16 AM Reply With Quote
For the front draw a line (I used a Lazer level) across the bottom arm, wishbone from chassis mounting bolt to middle of bottom ball joint, this should be level, for the top wishbone the ball joint should be an inch higher than the top wishbone chassis mounting bolts.
Consider 1/2 to 1 degree toe in, 1 degree camber and 3 to 6 degrees caster as a starting point.
This will give you something to start with, from there you change to suit you driving.
I eat to survive
I drink to forget
posted on 14/6/11 at 10:23 AM Reply With Quote
Have a gander through this book which covers the subject very well IMHO and doesn't demand you have £££s worth of measuring equipment.
http://www.veloce.co.uk/shop/products/productDetail.php?prod_id=V4207&prod_group=Performance Tuning & Modification&
GBaggott
posted on 14/6/11 at 02:50 PM Reply With Quote
If you want to have a good feel and predictable oversteer, drift (essential for finding the limits on track) corner weighting is a must. This is from track experience in old MK, old MAC 1 and present MNR
ALEXARAS
posted on 15/6/11 at 02:15 PM Reply With Quote
Thank you for your replies:
Do you guys agree with snapper's indication:
Tow in: 1/2 to 1 degree
Camber: 1 degree
Caster 3 to 6 degrees
What about Coilover adjustment ?
Locost 7 RS2000
Beach Buggy Rotary
lucy
posted on 28/7/11 at 12:21 PM Reply With Quote
I can understand how braking is affected when trying to slow down in a straight line, but being a simple soul I find it difficult to work out how it effects drifting or cornering. (I'm sure it does have an effect it's just that I just don't understand how)
