New Topic New Reply
Author: Subject: Chassis issue?
hucky
posted on 22/6/11 at 07:53 PM Reply With Quote
Chassis issue?
i collected my chassis a while back now, put it in the shead and been concerntrating on other parts.
but looking at it this week im sure theirs some bits that could be wrong maybe?
drivers support bracing i think this will be for that looks good to me?
passenger side i this is where problems may lay
the support bar is in the opposit way to passanger side but looks to stick out more than the body work would?
also looks like maybe a engine mount bracket has been fitted bit again stick out of the body work
i believe this to be a ron champion build using cortina axle and uprights.
can anyone tell from the bad pictures if i have anything to worry about ?
posted on 22/6/11 at 09:41 PM Reply With Quote
When you fit the aluminium panel it bends round the support bar and gives a bit of shape to the car side. The driver side was probably altered to allow for exhaust. I would cut it out and do it standard as well as cutting the engine mount out.
New Topic New Reply
