Author: Subject: Air drills - difference betwixt 3/8'' and 1/2''
pdm
posted on 25/6/11 at 06:59 PM Reply With Quote
Hi
Just looking at some air drills and after some advice please.
Machinemart list 3/8'' and 1/2'' air drills - could understand it for impact wrench or air wrench but what does this sizing mean for drills ?
thanks
r1_pete
posted on 25/6/11 at 07:03 PM Reply With Quote
The max size drill the chuck will take,,,,,
Ben_Copeland
posted on 25/6/11 at 07:05 PM Reply With Quote
Size difference is the chuck size 10mm or 13mm
Ben
Locost Map on Google Maps
Enter Your Details Here
pdm
posted on 25/6/11 at 07:07 PM Reply With Quote
Great thanks a lot.
907
posted on 25/6/11 at 07:22 PM Reply With Quote
There could be a speed difference as well.
Air drills I've used in the past with big chucks ran slower, 500 rpm (ish)
The smaller ones ran at 1500 or 2000 rpm.
Just a thought.
Paul G
pdm
posted on 25/6/11 at 07:46 PM Reply With Quote
Yes according to the catalogue, the 1/2'' is 1800 rpm and 3/8'' is 2200 rpm.
I thought slower was ok as it would be predominantly for metal ?
Thanks for info.
Ben_Copeland
posted on 25/6/11 at 07:50 PM Reply With Quote
Speed would depend on size of the 'ole
Ben
pdm
posted on 25/6/11 at 07:59 PM Reply With Quote
jacko
posted on 25/6/11 at 08:08 PM Reply With Quote
The physical size is different too the 12mm drill is bigger and heavy
pdm
posted on 25/6/11 at 08:14 PM Reply With Quote
Reckon I'll go to the store and have a look rather than getting straight off internet - least I know a bit more now.
Thanks everyone as always.
jacko
posted on 25/6/11 at 08:35 PM Reply With Quote
For general use 10mm drill will do you and for the odd times you need a 12mm drill bit get one turned down to fit in a 10mm chuck
