Irony
| posted on 28/6/11 at 01:25 PM |
Amp capacity of spade connectors
I have quite a selection of pre-insulated spade connections. They are all 6.3mm and I have the Red, Blue and Yellow varieties. I have been very
careful with wiring and made double sure I use the correct thick wire in the correct location. However I need to connect stuff together etc. I
haven't checked what current the 6.3mm connectors can handle. I assumed that if the cable fitted the connector then the connector could handle
the current.
Does anyone have any idea what the capacity is of this type connector?
speedyxjs
| posted on 28/6/11 at 01:40 PM |
The spade connectors i have, have the amperage stamped on them
big-vee-twin
| posted on 28/6/11 at 02:27 PM |
RED CRIMP
Area, wire size min:0.25mm²
Area, wire size max:1.65mm²
Current rating:19A
Material, contact:Copper
Material, insulator:Coloured Vinyl
Plating, contact:Electro-tinned
Temp, op. max:85°C
Temp, op. min:-20°C
Voltage rating, AC:415V
BLUE CRIMP
Area, wire size min:1.04mm²
Area, wire size max:2.63mm²
Current rating:27A
Temp, op. max:85°C
Temp, op. min:-20°C
YELLOW CRIMP
Area, wire size min:2.63mm²
Area, wire size max:6.64mm²
Current rating:48A
Temp, op. max:85°C
Temp, op. min:-20°C
http://www.triangleltd.com
| posted on 28/6/11 at 02:45 PM |
Nothing to do with cable size but a standard 6.3mm (1/4" Lucar spade connector is rated at 15 amps max. The next size up is 35 amps.
r1_pete
| posted on 28/6/11 at 03:06 PM |
True, and its always amazed me how much more vehicle manufacturers demand of them, the ignition switch connectors on my E Type can be called to handle
22-25 amps, i.e. lights on and then hit the starter button, as its a button not a second click on the switch, so the lights dont disconnect during
cranking. I'm working on a relay to kill the light circuit when the starter is pressed.
Irony
| posted on 28/6/11 at 03:18 PM |
Maybe me being fick but Big Vee Twin said that the yellow connectors can carry up to 48A and British Trident says 15amps. Who is correct?
| posted on 28/6/11 at 03:57 PM |
Yes it is pretty common to see them push way beyond the nominal rating, but I always keep in mind 35 amp spade connectors always gave on
alternator plugs because they were operating at too high a current.
[Edited on 28/6/11 by britishtrident]
Staple balls
| posted on 28/6/11 at 04:02 PM |
Both?
Looks like Big Vee Twin's numbers are from the crimps, rather than the spades.
| posted on 28/6/11 at 04:31 PM |
yes, 6.3 mm are used on alternators, higher output alternators have two of them in parallel, not sure what the crossover is from 1 to 2 but it is
around 40 A region
daviep
| posted on 28/6/11 at 05:33 PM |
around 40 A region
Normally the output spades are 9.5mm the spade for for the warning lamp is 6.3mm.
Davie
| posted on 29/6/11 at 01:49 PM |
^^^ you may well be right, I was thinking the common size is 4.7 mm so the next size up is 6.3 mm, as used on alternator..... just abot to check now
daviep
| posted on 29/6/11 at 07:00 PM |
4.8mm are used for audio connections and the like.
Davie
