tomgregory2000
| posted on 8/7/11 at 07:50 PM |
FS: 321bhp Luego Viento Price slash £6250
Luego Viento For Sale
I am selling my Luego Viento, built by myself over a few years
It started out with a c20xe engine running through a type 9 on twin 45 dellortos
I soon got used to the power so the quest for more began, and only 6 monts since passing sva the c20xe was removed and i came across an sr20det
This was fitted over the winter and now this engine has been in the car for 2 years now and my god its crazy now
The car passed sva on the first retest and date of first registration is 09 04 2009, failed due to a few sharp edges and the speedo not reading
correctly
The car has 9/8 months tax left and has done just under 2000 miles since passing
The reason for selling her is that i am starting on a new project soon, I have a 1987 land rover 90 that needs a full strip down and rebuild
Chassis and bodywork
Chassis is factory made buy Luego, powder coated black but is coming off in a couple of areas
Its double wishbone suspension all round with polybushes, and i had the crush tubes plated so they wont rust
The bodywork was supplied buy Luego as well but i believe they outsourced all the fibreglass work
The bodywork is in a bright red colour with alloy side panels
I have fitted my custom made aero screen but i ran out of time to get it painted so it is white
Engine and Transmition
321bhp sr20det engine from an s14 200sx, all alloy engine
760cc injectors
Z32 air flow meter
Uprated engine mounts, they are nice and stiff but remove the vibrations
Tubular exhaust manifold with t28 turbo charger, small ish size for quick spool up but still makes good power
Uprated wastegate actuator
SARD r2d2 dump valve
3" straight through exhaust
Sierra 2wd cosworth intercooler
Apexi air filter
Apexi power fc programmable ecu with hand held remote display
AVC-R electronic boost controller
Std 200sx gearbox
ACT superlight billet steel flywheel
Exedy uprated organic clutch
Custom made dunning and fairbank propshaft
Bosch 044 motorsport fuel pump
Pace products caterham 4 core racing alloy radiator
Running gear
3.92 ford sierra lsd rear diff
Front uprights are sierra 2wd but have been fitted with the calipers and discs from the xr4x4, the calipers have a larger diameter piston and
therefore giving you more stopping power
Rear disc brakes from an xr4x4 as well
2.9 ratio rack fitted (need to get the tracking done agen as i changed the rack last night)
Gaz adjustable dampers
Wheels
Fitted with team dynamics pro race 1.2 in silver
15" x 7" on the front fitted with 215/50/15 toyo r888
17" x 9" on the rear fitted with 275/40/17 kumho v70
Interior
2 fibreglass bucket seats fitted with red 4 point harness
VDO cockpit vision electric speedo driven from the pick up sensor inside the gearbox, with matching rev counter, water temp, fuel and oil pressure
Stack boost gauge
Bright 6 warning lights
Carbon dash fitted
And prob some other bits i cant remember at the moment
  Car 2
  Car 3
  Car 5
  Car 7
  Car 20
  Car 19
  Car 21
  Car 18
Only £6250
Phone no: 078 09 883 716
Email: tomgregory2000THAT 'AT' SIGN THINGhotmailDOTcoDOTuk
And im in the southampton area
daniel mason
| posted on 8/7/11 at 07:56 PM |
am not being funny mate, but why would you even consider selling it for such a low price?
i would keep it rather than let someone have it for that! its a lot of car for the money.
Gazjen
| posted on 8/7/11 at 08:23 PM |
Probably to temp me into buying it!
PX for audi S6?
tomgregory2000
| posted on 8/7/11 at 08:52 PM |
Sorry no part x
I really want to start my landrover 90 project and that means that i have to sell the kit car to get some funds and space to be able to do it.
I wish i could keep the viento AND do the project but unless i win the lottery i dont think that will happen
