New Topic New Reply
Author: Subject: gear lever
whitstella
posted on 17/7/11 at 07:37 PM Reply With Quote
gear lever
hi
just moving onto my next job after my brake pipes, anyway i have a type 9 box with gear lever in the usual place and i have got an adaptor to move the gear lever towards the back of the car only about 100mm. how does the piece of kit work and does anybody know what the hell im going on about. it was bolted on when i got the car but i doesn't do anything not even select a gear. i will try to post a pic if you need to see what i have got and possible what am i missing.
cheers fokes
Kev36
posted on 18/7/11 at 10:08 AM Reply With Quote
Hi, im having a similar issue.
bought the extension kit on ebay. there is a key which should fit in. but in my case the key is too wide to fit in.
(type 9) anybody fitted this kit?
thanks
kev
' A rich man is just a poor man ...with an awful lot of money..'
Miks15
posted on 18/7/11 at 10:40 AM Reply With Quote
a picture would probably be the easiest way to see what is going on.
JeffJeffers
posted on 19/7/11 at 12:27 PM Reply With Quote
Is this the part?
This is a part that Rally Design and Westfield supply.
It just bolts in place of the gear lever then the gear lever bolts in to it. Like you say it moves the lever back about 100mm.
whitstella
posted on 19/7/11 at 09:28 PM Reply With Quote
hi
all sorted now thanks i was missing the bit off the end where the gearlever goes.
cheers steve
New Topic New Reply
