madrallysport
posted on 20/7/11 at 12:21 PM |
Zetec idle problem
Guys, my aunts 1.8 focus zetec keeps cutting out, car starts fine but you have to keep blipping the thottle to keep it running, the car wont idle just
cuts out, it drive ok, but its a bit of a nightmare at the minute.
Any ideas or pointers what i should be looking to replace to repair it for her
UNDERSTEER is when you hit the wall with the front of the car.
OVERSTEER is when you hit the wall with the rear of the car.
HORSEPOWER is how fast you hit the wall.
TORQUE is how far you take the wall with you.
blakep82
posted on 20/7/11 at 12:29 PM |
how old is it? my bmw has been doing similar things, which ive sorted but now its got another problem...
anyway, mine was all to do with the air intake. mine was split between the air flow meter/sensor and the throttle body. ie it was getting more air
than it thought it was, not enough fuel,
the rubber intake was split where it joins the idle control valve, sprayed the ICV and air flow sensor with loads of carb cleaner and it idles fine
and accelerated better than ever. its a 16 year old car though
might give a starting point though?
________________________
big_wasa
posted on 20/7/11 at 12:56 PM |
The idle controle valves stick when there full of carbon. You could try some carb cleaner but a new one starts at around £30 job done....
edit also look for split vacuume hoses on the back of the manifold.
[Edited on 20/7/11 by big_wasa]
focijohn
posted on 20/7/11 at 07:11 PM |
On my 1.8 2000 focus, my idle control valve went and caused a similar issue. As and when it wanted it would cut out (at idle of course), normally at
lights. Was about 70-80 from a very poor memory. Is a fiddly job but doable with a small 1/4 ratchet.
HTH
John
Anyone going slower than you is an idiot. Anyone going faster than you is a maniac.
Too many targets but too few bullets.
focijohn
HTH
John
