New Topic New Reply
Author: Subject: Starter motor goosed?
Iaing
posted on 25/7/11 at 07:07 PM Reply With Quote
Help! My Indy starter motor doesn't want to turn the engine over. It turns it over maybe twice then makes a sort of whining noise like the motor is spinning on it's own and not engaging?
Fyi it's a 1.8 k series
This is not a problem I have encountered before but am assuming the starter motor or mechanism has had it? Any ideas?
Iain
snapper
posted on 25/7/11 at 07:46 PM Reply With Quote
Could be solenoid loosing power therefore the gear is pulling back and disengaging.
I use a bloke in Harlow who rebuilds them, cheaper than buying new more reliable than going to the scrappers.
I eat to survive
I drink to forget
Rod Ends
posted on 25/7/11 at 08:09 PM Reply With Quote
Seem to recall reading on Blatchat lots of postings about Caterhams having problems
with starter motors being damaged by heat from the exhaust.
Chippy
posted on 25/7/11 at 09:44 PM Reply With Quote
Before spending your hard earned, take it off give a good clean, check that the pinion is totaly without grease or oil, and refit. I have done this with the occasionaly recalcitrant starter, and most times it has wirked, if it doesn't then it's a re-con.
HTH Ray
Iaing
posted on 25/7/11 at 09:46 PM Reply With Quote
Thanks for the replies. First step I think is to get the starter motor out and investigate further
Iain
Mk Indy R - Hayabusa Power
New Topic New Reply
