Author: Subject: oil cooler on xe ?
nige
posted on 4/8/11 at 08:00 PM Reply With Quote
oil cooler on xe ?
anyone running an oil cooler on a c2.0xe
ive just been given one , its a little bigger then the stock one ( not much )
will it be overkill or o/k ?
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
billy
posted on 4/8/11 at 09:15 PM Reply With Quote
I've not fitted one on mine, you don't need it
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
loggyboy
posted on 4/8/11 at 09:20 PM Reply With Quote
Never needed one on my XE.
If you do want one, just make sure you fit a thermostat then it wont cool to an unnessacary level.
laptoprob
posted on 4/8/11 at 09:42 PM Reply With Quote
I have one on my 230 hp engine and turns out i didnt need one after all!!!
Dont bother....
http://www.youtube.com/watch?v=ajlF4nWJtGA
nige
posted on 5/8/11 at 07:42 AM Reply With Quote
thanks for that chaps
westy turbo
posted on 6/8/11 at 06:43 AM Reply With Quote
will it harm it? ihave one and its needed on hot track days
perksy
posted on 6/8/11 at 09:02 AM Reply With Quote
Its a good idea to monitor the oil temp before deciding *if* you need to fit an oil cooler and also keep an eye on oil pressure (make sure your using the right spec oil)
*If* going for an Oil cooler it needs a stat really so there's no danger of 'overcooling' the oil
as said above most folks don't need one but if your running a fairly high spec or turbo motor and doing track days etc
its worth checking oil temp and then making a decision
Run a Laminova on mine which helps bring the oil temp up to the right level
